How many of you guys are running +450whp on stock internals?
Old Nov 9, 2010 | 06:49 PM
BenJ's Avatar
Originally Posted by Don Q
Thanks alot for the helpful info. However, I started this thread because I wanted to know how many people ACTUALLY run their evos on stock internals with this kind of power. Many of us can say "well, I've heard." or "My buddy..." but not many say I DO have 450 on stock internals
Thanks alot for the info guys, guess I just have to watch out for the TQ
Did you not read the threads that I posted? They weren't for my own enjoyment you know. If you bothered to read them, you would have found many first hand experiences that answer your question exactly.
Or, I suppose, you can ask the same question that has been asked many times before and continue to beat the dead horse.
Old Nov 9, 2010 | 07:22 PM
Frew's Avatar
Originally Posted by gsrboi80
Tuning and mods for sure. Nice thing with the larger framed turbos is you can keep the TQ low to keep the factory rods happy while being able to ring it out up top if valvetrain is up to snuff
would the fp red,green, and black fall into this catergory?
Old Nov 9, 2010 | 07:48 PM
Don Q's Avatar
I did read them. However, those same people who were running that power at that time could've blown by now. Like I said, thanks for the info. Dunno why you are making such a big deal about it.
Old Nov 9, 2010 | 08:04 PM
Aaron20's Avatar
I have been running my 497AWHP 396AWTQ Evo VIII for about 8 months now, all on stock internals and it has done fine. Of course any motor will blow if you over stress it and all motors have a fail point. there is no magic trick to making your car indistructable, but if you want to put done 450AWHP it's doable with the proper tune and supporting parts. I recommend you talk to the shop that will be doing the work for you (if there is one and your not doing it yourself) and see what they think you'll need to do to make this happen and what the long term out come will be. My shop that I trust is English Racing and they said my car should be fine where I am, with the understanding that all motors have a breaking point and it can happen. It all depends on how hard you are on the car, how well you maintain it and of course the tune! I dont think you will have any problems at 450AWHP, if your tune is good and you dont redline it all the time or for a long period of time. Just my personal thought, dont beat your car....but it's ok to push your car! there is a difference!
Old Nov 9, 2010 | 08:51 PM
Don Q's Avatar
Thanks for the info man! Don't redline all the time? Hmmm I didn't thought much about that. Usually when I WOT, just run one gear and then let off or go 1-2 gears and thats it. But I do shift at the 7,900 that the car is tuned at
Old Nov 9, 2010 | 08:58 PM
Aaron20's Avatar
ping off your Redline as in miss shifts or over rev your motor. most of the times it happens on accident but thats when most of the serious damage occurs.
Old Nov 9, 2010 | 09:10 PM
Don Q's Avatar
Makes sense. I was thinking of installing a shift light, do you think it would be a good idea? I wanted to set the shift signal at 7,800 rpm so I could shift at 7,900. Maybe I should install one and set it at 200rpm below, so I can always be "safe"
Old Nov 9, 2010 | 10:08 PM
fabshopmiami's Avatar
Very good info on this thread.
Old Nov 10, 2010 | 05:07 AM
gsrboi80's Avatar
Of large frame turbos?? No
Old Nov 10, 2010 | 10:50 AM
Frew's Avatar
So what would?
Old Nov 10, 2010 | 03:28 PM
pls1968's Avatar
Numbers are in my sig. Been running the car hard for the past two years on the stock block. Have never broken anything. I have to attribute it's success to my tuners so far Jestr Tuning and now Diiirk @ AWD Motorsports as well as AMSOIL fluids in the engine, tranny, TC, and rear Differential.
Old Nov 10, 2010 | 03:35 PM
WRXGONE's Avatar
was stock bottom end with numbers below before the motor went POP because a rod bolt gave! fully built block now with higher numbers.......
Old Nov 10, 2010 | 03:40 PM
Smike's Avatar
Search, read, closed.
jficek34
27
Oct 20, 2014 04:40 PM
Don Q
20
Oct 26, 2010 08:57 PM
bowlersp
Oct 7, 2010 08:34 AM
HAHAV8
14
Aug 7, 2010 02:55 PM
yoderboy24
43
Feb 25, 2006 03:28 PM
