looking for info on a new intake.
Old Nov 10, 2010 | 04:27 AM
shrtstuff89's Avatar
I currently have the stock hose from turbo to air box, but took out the box and put in an Hks shroom filter. I've been looking at this samco intake tubing but not sure if it would fit directly onto the turbo and MAS. If you know plz post.
If it doesn't, does anyone know a different intake hose that does fit directly onto a stock turbo/MAS
Old Nov 10, 2010 | 05:02 AM
evo8426's Avatar
the perrin intake pipe fits stock airbox
Old Nov 10, 2010 | 05:21 AM
Jrah2987's Avatar
Veteran: Air Force
You could make any intake fit the turbo/maf with the right coupler. I believe most kits come with the couplers to fit stock turbo/maf unless they say otherwise. ETS kit does for sure.
Old Nov 10, 2010 | 06:13 AM
What about jm fab or samco sport
Old Nov 10, 2010 | 06:35 AM
Jrah2987's Avatar
Veteran: Air Force
If they come with the right couplers, then yes. Never bought either, so I can't say 100% yes or no. You can always call them.
Old Nov 10, 2010 | 06:53 AM
Kracka's Avatar
The Samco will work, it's a nice tube. The other good thing about silicone vs. metal intake pipes is you can trim them to fit your certain setup.
Old Nov 10, 2010 | 09:30 AM
domyz's Avatar
the stock air box is better for cold air with the ram, on a warm car on a dyno, it would hold hp much longer than an open filter that heatsink on the engine
Old Nov 10, 2010 | 09:38 AM
4xforce's Avatar
I use the Samco coupler hooked straight to the turbo inlet without any modifications. I have trimmed the MAF side a little to gain a bit more room on that side to retain the stock air box with a Speed Element filter inside. Works great, super stealth and made the numbers in my sig with it. I really like the Samco hose for it's user friendliness and the fact that it doesn't scream modified when Johnny Law pops the hood.
https://www.evolutionm.net/forums/ev...irbox-mod.html
There is a pic of my setup on page 7. This was all with the Samco. Best of all it was pretty cheap for everything involved.
