Boost Issues
Old Nov 16, 2010 | 09:54 AM
Countrystrong11's Avatar
Update....still only 11psi, im gunna have to bring it to the dealer and have them see if they can fix it
Old Nov 16, 2010 | 01:46 PM
djchopps0013's Avatar
Originally Posted by FQ-300
Sounds like you are running wastegate boost pressure 11-12 psi. You might want to start by checking there.
+1
I did same thing when I installed my AEM truboost and was like wtf man, until i learned how to work boost gauge.
Old Nov 16, 2010 | 01:57 PM
Originally Posted by djchopps0013
+1
I could see where this would be a problem, but i installed a boost gauge only, i wish it was a boost gauge/controller.
Im so lost and im started to get angry.
Old Nov 16, 2010 | 02:15 PM
KarmaSRT's Avatar
Yep go to a performance shop i wouldnt take it to a dealership they never know anything about evos
Old Nov 16, 2010 | 02:59 PM
H4RDCOR3's Avatar
pull the vac line goin to the wg actuator off then be CAREFUL and go brake boost and watch your boost gauge closely. See if it goes past 11psi. That will tell you if its the wg actuator spring or not.
Old Nov 16, 2010 | 08:15 PM
Does anyone know about any performance shops in the upstate NY area....Albany/Saratoga area?
Old Nov 16, 2010 | 08:44 PM
azinterrider's Avatar
Be very careful here. You may end up severely overboosting. Def not good for the motor. But it should tell you if your problem lies within the gauge or the boost control lines.
Old Nov 16, 2010 | 08:48 PM
Evo3573's Avatar
Check out stm! They do great work!
Old Nov 16, 2010 | 08:49 PM
Evo3573's Avatar
Here's a link for stm
http://www.streettunedmotorsports.com/contact.htm
Old Nov 16, 2010 | 08:56 PM
Originally Posted by Evo3573
Just did a map quest, its about 4 hours from my house......Ill make that trip once i need a tune and dyno.
Old Nov 16, 2010 | 09:03 PM
Evo3573's Avatar
4 hours is a hike. But it would for sure be worth it for the tune..
Old Nov 16, 2010 | 09:04 PM
Yea once i figure out this boost issue ill have to take a trip down there and get a tune
Old Nov 17, 2010 | 12:19 AM
rookievo's Avatar
Take it to a tuner that knows about evo's. Dealers wont help.
Old Nov 17, 2010 | 05:41 AM
Especially after they see aftermarket gauge. Most dealers are D's about it.
Old Nov 17, 2010 | 05:54 AM
4RETECH's Avatar
Try Frank at Autohaus. He put together the 2.3 for a buddy of mine. If he has any questions, he has my number.
