Boost Issues
Old Nov 17, 2010 | 12:13 PM
  #31
Countrystrong11's Avatar
Originally Posted by 4RETECH
Try Frank at Autohaus. He put together the 2.3 for a buddy of mine. If he has any questions, he has my number.
I planned on goin and talking to Nate there. i know hes a subbie guy but he knows his stuff.
Old Nov 17, 2010 | 09:02 PM
  #32
sparky's Avatar
Originally Posted by Countrystrong11
Ok...how do i change the wastegate spring pressure?
PM me and I´ll walk you through the process.: beer
Old Nov 17, 2010 | 09:28 PM
  #33
talonesi95t's Avatar
hello, im new to this site,,sorry for posting,,but im having the same problem with my evo i just bought...right now my vac lines are setup up from the intake to wastegate and i hit 25+ psi and when i have it hooked up from the j pipe to wastegate i get 10 psi. what could cause this? thanks and sorry for butting in this thread
Old Nov 17, 2010 | 09:37 PM
  #34
sparky's Avatar
You can either ¨T¨ off the line that connects the IM to the BOV, or alternately, source the boost reference directly from the comp hsg discharge tube(J pipe). So, which is it¿
Old Nov 17, 2010 | 09:52 PM
  #35
sparky's Avatar
talonesi95t Are you running a MBC, or still running the factory boost control scenario?
Old Nov 18, 2010 | 11:25 AM
  #36
ok so i adjusted the wg spring thanks to sparky.....and still the same readout. Could it be my boost solenoid?
Im so fawking lost right now, i want my car running normal boost.
Old Nov 18, 2010 | 11:39 AM
  #37
Just remembered someone told me to unhook the line the goes to the wastegate, and i did that and took it for a spin. I boosted over 11 psi, i let it climb past 15 then let off(didnt wanna overboost) So what does this mean? Wastegate bad? Boost solenoid?
Need some experts on this one
Old Nov 18, 2010 | 07:00 PM
  #38
bump
Old Nov 19, 2010 | 12:05 PM
  #39
RoryMarckese's Avatar
I had the same problem with my car. Still waiting on the replacement of my clutch to see if that was part of the problem with my lack of power. I did a boost leak test if u wanna know how PM me
Old Nov 19, 2010 | 12:10 PM
  #40
4g63evoeight's Avatar
go to synapseturbo in glenville.
www.synapseturbo.com.
a friend of mine owns the place (morgan), had him do a LICP and weld a tial Q on for me. tell him Peter Sent ya.
Old Nov 19, 2010 | 12:20 PM
  #41
H4RDCOR3's Avatar
Ok good, that means your wastegate is still working as it should. I would look into boost leak. Maybe leaking dv/bov? Or bad boost solenoid.
Old Nov 19, 2010 | 12:29 PM
  #42
Boosted Tuning's Avatar
You guys only getting 11-13 psi are running wastegate pressure and its probably because you dont have the correct lines, or more so, are missing the stock boost pills.
This is very common when the previous owner used a MBC/EBC and then tried to return the car to stock.
Old Nov 19, 2010 | 12:31 PM
  #43
H4RDCOR3's Avatar
+1. what are you using to control boost now? That could tell all lol
Old Nov 19, 2010 | 01:17 PM
  #44
I just ordered a boost solenoid, the bracket and the lines with the pills. It should all be here thursday...i dont have the pills in there now. So its all good hopefully ill let yall know how things turn out
Old Nov 19, 2010 | 01:19 PM
  #45
Deff. will stop by its about 10 mins away from my house. If your in the albany area we should meet up sometime and maybe hit up a car show or two, not to many evos around here...and the ones ive talked to the guys are dicks. It would be nice to cruise around with other evos, got a bunch of friends with wrxs
