Overboost w/ CEL. HELP!
Old Nov 16, 2010 | 08:48 PM
B Fletch LV's Avatar
So recently I put a 3" invidia n1 catback on my car. Car ran great, boosted to a little under 20 PSI like normal, and tapered to 16 like normal. About a week ago I added a megan 3" DP and a 3" test pipe. Now my car overboosts like crazy. From a start it pulls hard in 1st and 2nd but at 5500RPM in 3rd and 4th it hits the fuel cut and bucks, then pulls hard after. I tried to watch the gauge and today in 4th it hit about 24 PSI. I pulled a P0234 code (overboost) and have searched the hell out of this topic, but have not found any solid information on a fix.
I've basically read that a MBC could stop the boost from going too high but could still cause me to hit the fuel cut. Would a flash tune fix the overboost and fuel cut? I really wouldn't like to drop the funds right now for a MBC and tune.
Additional info:
Stock airbox, new spark plugs added not even a month ago, and gapped them all properly. The exhaust is my ONLY modification other than gauges and a stereo.
Thanks for any info.
Old Nov 16, 2010 | 09:28 PM
ReaperX's Avatar
Get a tune, if you want to boost above stock without a mbc then remove the boost pill
Old Nov 16, 2010 | 09:35 PM
I don't want to boost over stock I want it to boost like normal. Hence why I thought a MBC would be beneficial.
Old Nov 16, 2010 | 10:20 PM
Marroccowned's Avatar
sounds like a boost leak, I had the same problem...
Old Nov 16, 2010 | 10:31 PM
Earthen's Avatar
Add a boost controller to control the boost. Also get a tune to take care of the CEL and fuel cut. Simple as that.
Old Nov 17, 2010 | 07:31 AM
06RedRalli's Avatar
^ +1
Old Nov 29, 2010 | 05:32 AM
skipperbrent's Avatar
im throwing the same code, i have 3 in turboback
Old Dec 2, 2010 | 04:53 PM
evonky's Avatar
could have a wastegate stuck open??
Old Dec 3, 2010 | 05:33 AM
i dont think so. it only did it after i put the turboback on.
Old Dec 3, 2010 | 07:02 AM
Earthen's Avatar
I will quote myself. This is all you need to do.
Old Dec 3, 2010 | 08:34 AM
get a tune thru who? who is the best to go with?
Old Dec 3, 2010 | 08:40 AM
ethan169's Avatar
Evom vendors offering maps via ecuflash
Go here and talk to most any of these people. Any of them will do the trick some are better then others. I have personally used Mellon and hes great! I spoke a little with Tamer form 4WS and he seems to know his stuff as well.
This is a simple problem with a simple fix. Listen to what these people are saying. You need to a little more research on boost control for the Evo and the stock ECU...
Good luck
Ethan
Old Dec 3, 2010 | 10:09 AM
benselements41's Avatar
Samething happenend to me, you need a tune. You could keep your stock psi with a tune too!
Old Dec 4, 2010 | 05:51 AM
i think ill go with mellon. he is within 2 hours driving distance from me. so that will be my best bet
MitsuJDM
19
Nov 9, 2016 03:47 PM
REVOlution X
36
Oct 16, 2012 08:59 PM
fit4130bmx
Feb 29, 2012 05:14 PM
Red Dragon
13
Sep 9, 2011 06:42 PM
Thegame
10
Jul 25, 2007 12:01 PM
