Polished diff fluid resevoir
Old Nov 26, 2010 | 02:51 AM
superk1980's Avatar
polished diff fluid resevoir....where can i get one from? thanks
Old Nov 26, 2010 | 12:37 PM
jasons9594's Avatar
wtf?
Old Nov 26, 2010 | 12:57 PM
milford's Avatar
the same place you buy muffler bearings from duh
Old Nov 26, 2010 | 01:51 PM
TommiM's Avatar
Next to the spark plugs for diesels, above the radiators for 1970s vw bug.
Old Nov 26, 2010 | 02:04 PM
EvoooB's Avatar
^ Yup... same response. Maybe he means ACD fluid?
Old Nov 26, 2010 | 05:49 PM
still*boostn's Avatar
I would think so. people not thinking befor flaming.
answer for the OP, as far as I know nobody makes them.
Old Nov 26, 2010 | 07:04 PM
Speedlimit's Avatar
Admin Emeritus
Hi,
I have read a few of your responses across several threads and they are not helpful. In fact they are baiting and unnecessary. If you want to contribute, please do so, however please refrain from the confrontational one line drive bye's. Thanks.
Bob..
Old Nov 26, 2010 | 07:36 PM
EvoJoeIX's Avatar
ive never seen one but i bet if you call up JM Fabrications they could fab something up for you. i know they do custom stuff
Old Nov 26, 2010 | 11:26 PM
TommiM's Avatar
I apologize for not being more helpful. I dont know who makes an aftermarket polished reservoir for the acd system, but you 'might' be able to use one like the Forge unit thats meant for the power steering reservoir. The main thing is just knowing how much capacity the oem has vs aftermarket one. On that note my personal choice is the oem ones because you can visually see the fluid right there. hth.
Old Nov 27, 2010 | 02:59 AM
EvoJoeIX's Avatar
Having the correct amount of fluid is pretty important in the ACD system because the fluid level changes as you drive. Wouldn't want to have to little and you start sucking in air.... don't forget that
Old Nov 27, 2010 | 08:49 AM
+1, best answer yet.
If anything I dont know how your set up is but if your air filter is right by it you could try making a heat sheild/box around it, would hide it so you wouldnt see it.
OMEGA BLACK 79
17
Jun 27, 2018 05:57 PM
rcheung
33
Jul 10, 2014 08:35 AM
D-VO
10
Apr 19, 2013 07:23 PM
Daddymac
Jul 2, 2008 03:50 PM
forum04pl
Feb 18, 2006 02:35 AM
