Length of AEM Wideband Cable????
Old Dec 20, 2010 | 09:48 AM
gsrboi80's Avatar
Jon I know it'll be a bit more of a PITA but I would 180 that test pipe. I would not install the WB facing that way.
1. Closer to the ground (Can Pick up road debris and such damaging/breaking the sensor)
2. Moisture in the exhaust is may potentially just sit on the sensor since essentially it will be facing downward shortening sensor life and giving inaccurate readings. Any WBO2 company will tell you anywhere between 10-2 is optimal
Old Dec 20, 2010 | 11:10 AM
escodotcarter's Avatar
thats exactly what i was going to do.......i have a buddy that works a local shop and he can do it with the air tools..........BUT then i was thinking that my downpipe might also have a bung welded in it i just cant see it because i still have the factory undertray lol (million little clips ) .......i was hoping to go tomorrow and take a look. Hopefully the person who heatwrapped the DP didnt go over the Bung..............
Old Dec 22, 2010 | 08:12 PM
awdordie's Avatar
If the harness is not long enough just extend it. I had this problem when I moved my wideband from a frog eyes pod to a pillar pod. Guy at aem tech support said just to make sure u cut all wires the same length and extend the same length and of course solder and heat shrink them and your good to go. Its a pain but do wat u gotta do.
Old Dec 23, 2010 | 08:00 AM
ratwals's Avatar
The AEM cable is long enough, but do yourself a favor and weld a bung on your downpipe.
Old Dec 23, 2010 | 08:08 AM
from the research I've done....my understanding is that the difference is minimal.
Old Dec 23, 2010 | 09:45 AM
blknblubkrdude's Avatar
AEM is pretty generous with the length of the cable.
I ran mine from my steering coulumn pod, through the grommet to the left of the dead pedal, through the LF fender, back into the engine bay, and down the exhaust about 30 inches.
Old Dec 23, 2010 | 09:52 AM
boostedwrx's Avatar
You can always extend the cable
SnailSpeed
Jul 23, 2017 12:35 AM
discodino
Feb 22, 2017 03:01 PM
HaVoC RR
10
Feb 19, 2011 11:19 AM
racer135
Jan 5, 2010 08:23 PM
skold
Dec 6, 2007 08:52 PM
