E85, Regulated? Questions on fuel quality.
Old Dec 21, 2010 | 07:01 PM
420a-t's Avatar
^Lol
WolfsFang's Avatar
Originally Posted by metalsaber
Yes
dammit i just found a E85 station 3 mins from me. Looks like summer will be the cars first tune
Old Dec 21, 2010 | 08:55 PM
4RETECH's Avatar
You need more than just a tune for your stock car.
Injectors, fuel pump,and a tune.
And if you were going to switch back to 93, you would need a MAP switch for the ECU to run two Maps.
Also, I talked to an engineer from Ford Truck division.
He told me that during the testing with E85 in his trucks, they needed to upgrade the entire fuel system to stainless,from fuel tank to injectors due to the fact that E85 absorbs so much moisture.
He also said that over time, if the car was not outfitted correctly, the fuel system might last 3 years at the most.
The only way to help it was for every 2-3 tanks of E85, they would run a tank of 93.
Old Dec 21, 2010 | 09:03 PM
WolfsFang's Avatar
Yea i know you gata upgrade alot of things. The station is in spring valley at the sunoco station. I gata see the price to see if it is worth upgrading.
Old Dec 22, 2010 | 05:42 AM
drewbird91's Avatar
E85 will be cheaper than normal 93 octane gas, but you will be using roughly 30% more fuel. Its probably not worth it for you if your doing it just for cheaper gas.
To the OP, I was running E85 in my 1g for awhile and when I got the evo I decided that I'm going to stick with 93 octane because E85 was just too much of a hassle for a daily driver on a DSM. Anything below 40* it would be a bear to start, and having to plan trips to the gas station wasn't convenient. I took it to the shootout one year and mapped out and called all the e85 stations on the way and it took about 1 hour longer. It all depends on your goals, if you can get there with 93 octane might as well do it, if an E85 station was next door to you that would also be a different story.
Old Dec 23, 2010 | 09:16 AM
mrfred's Avatar
With E85 so widely discussed on EvoM, I'm amazed that people ask if a retune is needed with E85 (as well as the needed hardware upgrades).
That must be for Ford-spec fuel hoses. I've been on E85 pretty much full time for 2.5 years and no sign of any degredation of any of the fuel hoses. My Walbro is still doing fine as well.
Old Dec 23, 2010 | 09:23 AM
mrfred's Avatar
Originally Posted by evowner17
I have been contemplating going the E85 route like so many people have these days, but I have several questions.
1. In my town there is only one place to get E85, and its 30 miles away. I know that e85 is hydroscopic, so it will absorb water over time. If I were to store it in a 55 gallon drum, how long will it stay fresh?
2. I have tested the fuel at the station a few times to see what kind of blend is actually coming out of the pump. The numbers I get seem to differ each time. (I use the graduated cylinder method for calculating %). I have gotten a wide variety of blends from E60 to E90...
3. My question is: Are there any regulations on E85? It doesn't seem like it to me. Perhaps it's just the station I am going to, but has anyone run into problems with inconsistent blends and had drivability issues?
4. If you get a crappy blend, such as E60, will I run into problems with knock and such? Does anyone on here test the fuel each time before putting it into your car? If that is the case ethanol seems like it would be a major headache..
Any input would be greatly appreciated, Thanks!
If you took all your measurements in July, did you make several measurements in each sitting to make sure you're doing the measurement in a consistent way?
As others have said, driving 30 miles each way for E85 is going to get old really fast even if you are filling up a 55 gallon drum. I think I'd want to fill up at least two drums to make it worth it.
Old Dec 23, 2010 | 12:11 PM
turbo dragon's Avatar
Im thinking of going E85 too, this thread has been helpful, so would it be better to get the local shop to order a drum of it so its consistent. or will getting at the pump be good
Old Dec 23, 2010 | 01:52 PM
RazorLab's Avatar
I don't think my Evo got that memo...
Old Dec 23, 2010 | 09:56 PM
WolfsFang's Avatar
Im hardly on this site, if i am its just a quick look.
Prosdoc
Aug 4, 2015 07:18 PM
car_nut15
Toronto Lancer Club
Oct 22, 2011 08:08 AM
TurboTim06
Northwest Region
Oct 7, 2011 01:32 PM
tvor
E85 / Ethanol
10
Mar 9, 2010 07:35 AM
Kc2Buk
61
May 5, 2006 11:39 AM
