Trouble Starting... Looking for more ideas.
Old Jan 1, 2011 | 09:37 AM
WarmPepsi's Avatar
Originally Posted by def1
are u throwing any codes? this is how my car acted when my crank sensor went out
nope. Literally let car sit a bit ( was a bit hairy in the snow ), started it up, swapped garages, came back to it and nothing...
Old Jan 1, 2011 | 09:44 AM
aka.ralliart15's Avatar
Check your fuse box in the engine, check if fuse #15 is working. If you dont have a way to check get some replacements at Walmart for $4 and swap it. I had the same problem yesterday cause some idiot put a wire instead of the fuse in the box. Its worth a shot to check it out. There's a diagram under the box cover to tell you which one #15 is btw.
Mine did the same thing yesterday and I thought it was the pump too.
Old Jan 1, 2011 | 09:47 AM
WarmPepsi's Avatar
checked all the fuses inside under the steering wheel and under the hood... all looked good.
Old Jan 1, 2011 | 11:46 AM
Routybouty's Avatar
If you still haven't solved if the Walbro is working or not you can turn it on in Evoscan. You could also then remove the return side near the fuel rail and run it into a bucket and run it again.
Old Jan 1, 2011 | 12:45 PM
saxon's Avatar
have you pulled your plugs?
i bet the cold start was never really tuned and you fouled your plugs, so now everytime you try to start it your just fouling your plugs
see who tuned it and see if they can help you out and start with a fresh set of plugs
Old Jan 1, 2011 | 05:15 PM
WarmPepsi's Avatar
Ouh... good call. I'll check that out..
Old Jan 1, 2011 | 05:21 PM
05blue8's Avatar
To test for fuel I unbolt the feed line from the rail or use evoscan. You can test all your injectors also. To test for spark pull a plug wire and put a screwdriver in the cylinder. Could be your tune also. My V7 wasn't set right so it took 4 separate cranking "sessions" to start my car. Fuse 1 is the main one under the dash that would cause that exact issue. Just replace it if you haven't. Did you pull every fuse?
Old Jan 1, 2011 | 08:00 PM
barneyb's Avatar
You look at a fuse and if the element is there the fuse is good....Not always so. The element (the wire that vaporizes when the fuse blows) may also crack or come unsoldered. The fuse will look good but be open. Just replace all the fuses associated with ignition.
Old Jan 13, 2011 | 05:23 AM
WarmPepsi's Avatar
just an update for anyone else with the issue... GOT IT RUNNING!
Swapped to some new (read: cheap) plugs, cranked over and hit first time. Let it run, get warm, drove it around a little (pretty cold here). Stopped, swapped back to the iridiums, it hesitated first turn, but second hit, started right over.
I'm guessing the fuel WAS frozen, and i somehow just fouled the plugs so badly, that it wouldn't start at all... Anything after that just made them worse. Pulled them out, and yeah, they were black... but not super bad at all. So yeah, check your plugs.
Old Jan 13, 2011 | 05:59 AM
saxon's Avatar
turbotaloon95
E85 / Ethanol
14
May 7, 2019 03:52 PM
Wmu240
Sep 8, 2015 06:21 PM
Hotsauce101
May 14, 2015 09:50 PM
Creatre
May 11, 2015 05:09 PM
sti killr
Jan 1, 2011 12:46 PM
