woohooo!!
Old Dec 8, 2003 | 01:40 PM
rbm3's Avatar
woohooo!!
I'm not sure if any of you have seen my "my car is broke" posts, but I finally broke down and took it to a local dealership/shop. The guy said the reason the car was bucking was because the stock spark plug wires from kind of suck and cannot make the plugs produce enough ignition to burn the extra fuel, he said it was very common among evo's (atleast here in Japan). And the reason my car was stalling is because I have an aftermarket BOV, and that tube that goes back into the intake isn't there, which pushes air back into the intake to prevent the car from stalling. He told me to tighten the BOV spring to see if it helps..so far it hasn't stalled yet! I'm also having him hook my HKS EVC III back up!
Old Dec 8, 2003 | 01:55 PM
silverEVO8's Avatar
Re: woohooo!!
Did you also replace the wires? If so, what brand did you use? What wires are the tuners over there using?
Thanks
Old Dec 8, 2003 | 01:58 PM
MalibuJack's Avatar
Yeah.. FWIW I am noticing issues which feel like timing being pulled, but I'm convinced its spark or plug wire related.. but nobody that I know of has replaced the wires (and/or added an ignition box) that I know of.. So I'm also curious about any improvements by replacing the wires.
Old Dec 8, 2003 | 02:10 PM
silverEVO8's Avatar
Yeah, Shiv did mention somewhere about sparkplug related timing pull issues... Al says it's all due to bad gas, but I wonder if some "noisy" engines (like mine :P) might not have some missfire issues? I would be very keen on changing the wires and/or plugs if this could help the noise reduction.... Maybe this thread should be moved to the Evo Engine / Turbo / Drivetrain forum?
Old Dec 8, 2003 | 03:37 PM
neonsalamander's Avatar
is a '93 an Evo II or Evo III?
How has it been holding up besides those problems?
Old Dec 8, 2003 | 04:41 PM
silverEVO8's Avatar
Hmmm.... I assumed he was posting about an EVO 8.... I guess it's not even close eh? Geez, I ought to pay more attention. Thanks for the heads up
Old Dec 9, 2003 | 12:00 AM
rbm3's Avatar
It's an Evo I..late model. Other than those problems it runs great!
Old Dec 9, 2003 | 07:14 AM
cotmfk's Avatar
Awesome, an EVO 1!
Sorry to hear about your problems. I had a similar problem on my old VR-4. My plug wires had been fouled somehow when the y-pipe came off. Replacing the wires did help this problem. Since your car is a 93, this might have occurred with you as well. It does sound like you are already in capable hands, though.
Post some pics of your car if you get the chance.
siaw
May 2, 2013 06:14 AM
dubbleugly01
Oct 5, 2006 09:32 PM
olschool
14
Apr 4, 2006 07:56 PM
ArchieBabes
Feb 23, 2006 08:42 AM
Hittman
17
Jul 22, 2004 08:55 PM
