Aem Uego o2 sensor question
Old Jan 12, 2011 | 05:23 PM
VKEVO's Avatar
What sup guys, I just received the aem uego today and I had read and understand that the best way to mount the 02 sensor is on top of the test pipe or horizontally. Other positions would harm the sensor. .. I currently have the auto meter a/f gauge and it's not too accurate. So can you guys please tell me is the current 02 sensor I have right now mounted correctly so that I can go ahead install the new one provided by aem. Here is the picture of current 02 now and this is how it is when I bought the car...
Old Jan 12, 2011 | 05:36 PM
4G63kevin's Avatar
I thought all o2 sensors were suppose to be facing upwards-ish. lol
Old Jan 12, 2011 | 05:43 PM
erald01's Avatar
no thats fine just take the o2 sensor out and replace it with the wide band sensor.
Old Jan 12, 2011 | 05:48 PM
VKEVO's Avatar
thank you guys
Old Jan 12, 2011 | 06:01 PM
EvoJoeIX's Avatar
if you look in AEMs directions they tell you how to place the sensor
they are supposed at about a 10 or 2 oclock position in the exhaust pipe
Old Jan 12, 2011 | 06:23 PM
VKEVO's Avatar
The one i have right now looks like it positioned at 3 oclock, is that good?
Old Jan 12, 2011 | 06:28 PM
EvoJoeIX's Avatar
i would just use the bung thats there. its not really worth all the trouble to take it out, fill in the old bung hole, and weld in a new one
ETS put one in my downpipe facing the same way as you pictured. thats how i run mine and it seems to be fine
Old Jan 12, 2011 | 06:30 PM
VKEVO's Avatar
thanks, you're the man.
Boltz.'s Avatar
FCOTM Winner
The only problem would be ground clearance. The sensor doesn't know what position it's in.
Old Jan 12, 2011 | 06:32 PM
erald01's Avatar
yes any position is good as long its not at 6 oclock position. And why does the angle matter?? whats the purpose??? Actually the sensor is supposed to be as close as possible to the exhaust manifold, BUT not too close that it will burn. It will give you more accurate read. At the test pipe is fine too and a lot of people use it because its easy to replace the stock o2 sensor.
Old Jan 12, 2011 | 06:34 PM
VKEVO's Avatar
Now you really pointed out the whole thing. So basically we don't want the 02 to come to close to the ground.
Old Jan 12, 2011 | 06:37 PM
EvoJoeIX's Avatar
im not sure why the angle matters. i was only stating what it says in the aem installation manual.
the only thing i could thing of if the sensor is pointing down (head up) is condensation from the exhaust system could form on the sensor and since its pointing down water could get into the sensor and ruin it. im not sure if these sensors are waterproof or what. with the sensor pointing upwards, the water wouldnt be able to get down into the sensor.thats only my prediction, dont hold me to it
Old Jan 12, 2011 | 06:40 PM
VKEVO's Avatar
i'm going to put mine in tomorrow, thank you for answering my questions^^^^^
erald01's Avatar
^^^ good point never thought of the whole condensation thing
Old Jan 12, 2011 | 06:43 PM
4G63kevin's Avatar
In that position, it worries me about ground clearance. If you're dropped, the sensor may catch something.
