How much boost lost TB seals
Old Jan 24, 2011 | 07:09 AM
  #31
achilles3000's Avatar
Picked up 25 whp and 300 rpm spool up from seals!!Must do them!!
Old Jan 24, 2011 | 07:28 AM
  #32
GreenAWD's Avatar
Worth while mod. I'm putting MIL. Specs in mine as soon as the weather warms up a little.
Old Jan 24, 2011 | 03:21 PM
  #33
kakarot305's Avatar
damn i defenetly need those seals 437+20=457 nice lol
Old Jan 24, 2011 | 03:31 PM
  #34
evotuner04's Avatar
15 Year MemberLikedLoved
yup mine went bad and i had a tune scheduled but the tuner was like theres no point to bother with this...we got the seals and were good to go
Old Jan 24, 2011 | 03:34 PM
  #35
YogSaahoth's Avatar
Veteran: Army
for sure...as I said, I changed the turbine housing to the 10.5, so the peak hp increase was probably mostly due to that, but the spool up and some of that extra torque in the mid-range has to be from the seals...in the boost leak test they leaked almost immediately. Ur car will most likely pick up a bit more power (all over the powerband) but will feel so much cleaner and more responsive.
Old Jan 24, 2011 | 03:45 PM
  #36
kakarot305's Avatar
mines do too leak the moment i put pressure in the system am really looking foward to change them
Old Jan 24, 2011 | 06:09 PM
  #37
5 ltr. beater's Avatar
Originally Posted by EvoJoeIX
Getting a car tuned with a boost leak is like wiping before you poop, makes no sense.....
Wait on the tune until your car is 100% or your just throwing money away
...now wait...a boost leak (from the TB in this case) doesnt have much of an effect on performance because the turbo just has to work a little harder to make the same amount of boost prior to the leak...
now if a hose pops off or something i can understand, but a TB shaft seal leak isnt that bad.
granted im on the stock turbo, i didnt see any change on my boost gauge before or after i did the TB shaft seals.
i dont see how a leak that small small can affect performance other than make the turbo work a little harder.
Old Jan 24, 2011 | 06:24 PM
  #38
EvoJoeIX's Avatar
why would you want to make the turbo work harder on something that is so easy to fix.....
boost leaks make a difference. end of story
Old Jan 25, 2011 | 09:57 AM
  #39
oh i totally agree with not trying to make it work harder, but the way its being depicted, is as if you're losing an insane amount of HP to the wheels.
i was just disagreeing because i had not noticed any unchanged amount of HP from the vehicle from doing the TB shaft seals before and after.
Old Jan 25, 2011 | 04:04 PM
  #40
Brsox10288's Avatar
If you have a bad boost leak from the seals, that can cause you to lose psi whih will make the turbo work harder and blow hotter air which in turn will decrease hp
Old Jan 26, 2011 | 12:04 AM
  #41
My03evo's Avatar
Like someone else said, the turbo overspooling is not the only problem...it's mainly that the MAF is reading a certain amout of air, it puts in a certain amount of fuel because it expects that much air but if some is leaking out now it's not running where it should be so it can now be richer and losing power, and not just that now that is also a vacuum leak which now makes you run lean when you're not in boost and have a higher idle depending how bad it is. and then that affects your fuel trims and that can affect driveability, fuel mileage, etc.
You're not going to see a change on your boost gauge unless you know the exact rate how fast your turbo builds boost at what load and can see the difference but I doubt it since there's too many variables. Either way you're going to end up making the same boost but the turbo will just be spinning more working harder to hold that psi and your spool time will decrease since once it starts to build boost it's already started to leak out.
Old Jan 26, 2011 | 03:53 AM
  #42
ODUB's Avatar
Originally Posted by bigben
Reschedule the tune, or you will be wasting your time and money
this
Old Jan 26, 2011 | 05:26 AM
  #43
dillon410021's Avatar
the gaskets can dry out and fail
Old Jan 26, 2011 | 09:46 AM
  #44
makes sense. i understand now.
Old Nov 3, 2011 | 11:45 PM
  #45
Yonkers9se's Avatar
hey just wondering i did a boost leak test sounded like it was coming from the tb i recently got the car tuned and the second i hit the street the boost would die out at 6k and the afr went to 10.1 and my vacuum is only at -16 at idle...i really hope its the seals
