cold start up?
Old Jan 19, 2011 | 09:27 PM
ch1215g's Avatar
SUSPECTED SCAMMER
cold start up?
so i got hks cams and when i start the car when its completely cold.. i have to hold the gas to let it idle until it warms up.. if i dont it stalls... any ideas what this could be... would a simple tune fix this?
Old Jan 19, 2011 | 09:28 PM
evolution666's Avatar
Believe it or not happens to alot of people. Ill let the experts chime in.......
Old Jan 19, 2011 | 09:38 PM
evo9ben's Avatar
you need a tune
Old Jan 19, 2011 | 09:40 PM
ch1215g's Avatar
SUSPECTED SCAMMER
ahh alritey... what about belt noise im assuming (squeaky sound)
Old Jan 19, 2011 | 09:41 PM
Lancerguy'03's Avatar
Originally Posted by evo9ben
you need a tune
thats pretty much it. i have HKS cams and dont have an issue.
to the OP: no check engine lights or anything? if not, just get the tune.
Old Jan 19, 2011 | 09:43 PM
ch1215g's Avatar
SUSPECTED SCAMMER
nope no check engine lights at all. car runs perfect when its warm
Old Jan 19, 2011 | 10:04 PM
Tfresh's Avatar
I had a problem with mine before and I adjusted the biss screw slightly and it fixed my problem. I run kelford 272s in mine
Old Jan 19, 2011 | 10:16 PM
ch1215g's Avatar
SUSPECTED SCAMMER
whats the biss screw?
Old Jan 19, 2011 | 10:19 PM
Tfresh's Avatar
its the base idle set screw
Old Jan 19, 2011 | 11:11 PM
06RedRalli's Avatar
You need a tune to raise the timing numbers in that cell area...I would recommend that before touching the biss screw...actually I would advise against it...
Old Jan 19, 2011 | 11:14 PM
ch1215g's Avatar
SUSPECTED SCAMMER
going to get a tune first thing in the morning! hopefully the shop im going to can take me without an appointment !
Old Jan 21, 2011 | 01:09 AM
yeah it should fix your issue without a doubt. but let us know how it went. cause you might have to adjust the biss screw, but the shop should help with that.
Old Jan 21, 2011 | 07:51 AM
achilles3000's Avatar
What size injectors you have?
Old Jan 21, 2011 | 07:59 AM
mifesto's Avatar
i dont think raising timing will help his car as increasing timing on a cammed car simply reduces the lopyness. sounds like OP has bigger issues then that, maybe he played with the idle screw only (and too much) and now BISS setting is conflicting and fighting his change. lopy cams will compound the issue but doesnt sound like its the primary issue.
Old Jan 21, 2011 | 08:04 AM
I get those issues sometimes too but then again I have 1,200 cc injectors on s.d those injectors flood the car on starting so if you don't touch the gas while cranking it stalls.
