Everything I've learned after 4+ years with my Evo
Old Feb 21, 2011 | 03:27 AM
  #121
evolutong's Avatar
Subscribed
Old Feb 21, 2011 | 07:33 AM
  #122
High_PSI's Avatar
Originally Posted by recompile
I referred to the XTSS, which is the one everyone has problem with. And even if someone didnt know about adjusting their clutch, it would be the first thing that came up if they searched EvoM for how to fix lockout issues.
There is nothing regurgative about the long, long, LONG list of people who hate their XTSS. Search for the "ACT, you suck" thread for an example, there are many, many bad testimonials from knowledgable enthusiasts and long-time shop owners including DB.
I have an XTSS and i don't have an issue, so your statement above is false. It is really hard to qualify a statement like that when you paint with a broad brush.
I love my XTSS and if it had a Vajayjay I would totally service that as well.
Old Feb 21, 2011 | 07:42 AM
  #123
NOMIEZVR4's Avatar
Wish this thread was made a year ago, I would have saved a ton of time!
Old Feb 21, 2011 | 11:11 AM
  #124
dRiFtInG_mR's Avatar
hmmmm.. dont everybody use amsoil for fp turbos? at least thats what i've been seeing! great advice though!
Old Feb 21, 2011 | 02:33 PM
  #125
FERNO's Avatar
Thanks OP.
I particularly like the part about "if I started over with $1000, this is what I would do". Interesting to hear that a "protune" may be overrated. Looks like I need to head over to the ECU forum.
Old Feb 21, 2011 | 06:39 PM
  #126
dsm2308's Avatar
I had no idea about the mobil 1 situation. Would it be ok to switch to amsoil with my next oil change or would it not be good for my engine since i have been using mobil 1 for the life of the car up to this point?
Old Feb 21, 2011 | 07:15 PM
  #127
Ian0611's Avatar
While I agreed with most of your original post this is one fact that I definitely can't agree with. I had an ACT XTSS put in about 6 months ago and it works flawlessly! I'm wondering if maybe ACT put out a bad batch of disks or something back when you guys were having all of those problems, because I've seen at least two threads in recent months where people have been raving about the ACT Xtreme clutches.
Old Feb 21, 2011 | 07:16 PM
  #128
wizzo 8's Avatar
There would be no problem switching
Old Feb 22, 2011 | 12:22 AM
  #129
scothu's Avatar
it's ok.. not really something to freak out about unless you are running high boost
Old Feb 22, 2011 | 12:25 AM
  #130
FJF's Avatar
FJF
There is no Mobil1 situation. If you're not running an FP Red/Black or a built motor there are no issues with the factory recommendation.
Guys, there's a huge thread about this. How about reading a bit?
Old Mar 2, 2011 | 03:45 PM
  #131
cobb-sti's Avatar
OP. Is the act hdss clutch the same as what you mentioned (ACT Xtreme Street Clutch) or different? Please elaborate!!
thx
I love redline motor oil it is really the way to go.
Old Mar 2, 2011 | 03:49 PM
  #132
recompile's Avatar
No, the Xtreme is the XTSS. Same disc but stiffer pressure plate. It's the pressure plate that causes the lockout issues.
I want to say that, the clutch is fine in every other way. Pedal feel is great. Durability is great. Holds tons of power... but all that means nothing when you can't shift above 7000RPM.
And it's worth noting that, the lockout usually only occurs after a hard launch & clutch slip, presumably after heating it up pretty good.
Old Mar 2, 2011 | 03:50 PM
  #133
wizzo 8's Avatar
Im sure if the OP could add something it would be dont hydro lock your motor
Old Mar 2, 2011 | 03:55 PM
  #134
High_PSI's Avatar
Funny, mine never does that.
Old Mar 2, 2011 | 04:08 PM
  #135
recompile's Avatar
High PSI, I understand you love everything about your XTSS, but there's a reason the ACT, you suck thread has endless negative testimonials. And it's not because David Buschur doesn't know how to adjust his clutch pedal.
Your one positive experience vs. dozens and dozens of negatives doesn't hold up, so go troll somewhere else.
