What O2 housing?
Old Feb 19, 2011 | 01:56 PM
PDCC_EVO's Avatar
What O2 housing?
Curious as to what O2 housings you guys are running on stockish turbo setups. I have been looking around at the different ones available that I could find, Titek, Invidia, JMFab, Megan, Authority........... The O2 is the only part I need to complete my exhaust system. Tanabe downpipe on the way and tanabe axle back already on the car. Any info or problems anyone knows of on O2 housings is greratly appreciated, I am also noticing in the pics some housings simply have just a small strip of metal for the twin scroll divide then just opens up to one inside piece and some have the waste with its own pipe welded back into it, does it really matter?
Old Feb 19, 2011 | 01:59 PM
06MREvo's Avatar
There are tons of debate between recirc and dump 02 housings...I am personally a fan of 02 dumps...I am on my 4th 02 dump and Toxicfab is easily the best quality and fitting dump out there...Check it out...
https://www.evolutionm.net/forums/ve...dump-look.html
Old Feb 19, 2011 | 02:30 PM
4RETECH's Avatar
I have the titek,installed some megans(boost creep unless you open the hole),Map dump and Map O2 copy of the titek.
The dumps are loud, but if would get one, it would be the shearer dump.
Old Feb 19, 2011 | 04:17 PM
PDCC_EVO's Avatar
I am more than likely not going with a straight dump.
Old Feb 19, 2011 | 04:32 PM
erald01's Avatar
Megan o2, cheap and it does the job. Search Megan o2 housing and you will find plenty info on it.
Old Feb 19, 2011 | 05:55 PM
Speed_Freak's Avatar
I have used stock, DME and Shearer dump pipe. DME and Shearer both about the same. I prefer the Shearer because when you hit boost, it sounds like a raped gorilla.
Old Feb 19, 2011 | 07:41 PM
Chadwich's Avatar
I have a megan
See if this will help
http://www.modified.com/tech/modp-09...iii/index.html
Old Feb 20, 2011 | 06:40 AM
PDCC_EVO's Avatar
Originally Posted by Chadwich
I have a megan
Man thanks, great find.
Old Feb 20, 2011 | 08:42 AM
Chadwich's Avatar
glad to pitch in
Old Feb 20, 2011 | 10:02 AM
Chadwich's Avatar
Take it down to a shop and have them port it out a little more.
When I got mine it just looked like someone drilled a hole about 1 inch in diamitor and went back in forth with it twice.
take it to an exhaust guy give him five bucks for about ten minutes of his time and it will be a lot better.
Old Feb 20, 2011 | 03:13 PM
D-Mon3y69's Avatar
Absolutely love my map performance o2 dump, would strongly recommend.
http://www.maperformance.com/maperfo...2h-ss-evo.html
Voltexed
15
Feb 21, 2013 11:33 PM
Svendiesel
195
Jan 24, 2012 10:46 AM
iridebmxnj
Sep 10, 2010 04:34 AM
john blaze
Nov 16, 2009 05:26 PM
ChrisBond1
Automotosports - Illinois
Sep 10, 2009 05:12 AM
