Evo VIII. Exedy Twin making a loud shudder sound in reverse or 1st
Old Feb 20, 2011 | 09:55 AM
SmurfZilla's Avatar
It only seems to do it at the point of engagement. Or when there is high load on the motor (like being in the wrong gear aka too low a gear).
It shudders like a CV axle that really broken. This starting happening after pulling out into traffic a little spirited.
Before all of this my friend had his evo rebuilt and had the clutch inspected and it seemed like the clutch was fine.
This is a Exedy Twin. Once the car gets that point it drives fine.
Old Feb 20, 2011 | 09:56 AM
05blue8's Avatar
Are you sure you are giving it enough gas? Sounds like you're trying to let the clutch do too much work...
Old Feb 20, 2011 | 11:21 AM
KX250Fmotoracer's Avatar
just sounds like clutch chatter
Old Feb 20, 2011 | 04:52 PM
anthonyrb98's Avatar
i had a similar sound on my clutchmasters twin disc. ended up breaking the discs.
Old Feb 20, 2011 | 09:49 PM
waynea's Avatar
I had a similar problem, it helped to move my engagement point up, but I am still not completely happy, you have to be gentle with the twin.
Old Feb 21, 2011 | 01:00 PM
06MRericctho's Avatar
is it the exedy heavy duty twin disk clutch?
Old Feb 21, 2011 | 06:17 PM
Evojj25's Avatar
i have a exedy s2 hd clutch im hearing the same sound as well and its like its touching something or grinding on something and i hate the noise.
Old Feb 21, 2011 | 06:23 PM
EvoJoeIX's Avatar
thats clutch chatter. completely normal when running a multi-disc clutch
Old Feb 21, 2011 | 06:27 PM
SmurfZilla's Avatar
This......I have a triple on my evo so i';m used to clutch chatter....this sounds/feels more like a violent shudder.......it pretty much happens in any gear as long as there is high load on the motor (aka low rpm high gear).
Old Feb 21, 2011 | 07:00 PM
Evojj25's Avatar
it does sound like a violent shudder.
Old Feb 21, 2011 | 07:01 PM
Evojj25's Avatar
but some reason it sounds like mine is getting loud.
Old Feb 21, 2011 | 08:44 PM
slowbaru's Avatar
hmmm mine used to shudder, but then again.. the flywheel was really noisy
Old Feb 22, 2011 | 10:36 AM
SmurfZilla's Avatar
No definitive ideas hunh guys? Trying to help a friend out......esp. if this happens to my car, I'd like ot have anidea on where to start.
Old Feb 22, 2011 | 11:24 AM
MikeB@FFTEC's Avatar
Sounds pretty standard to me. How long has the clutch been in the car? Has the clutch always made the noise?
Old Feb 22, 2011 | 12:42 PM
Donkeypuncher's Avatar
I have the same clutch, this was happening during the time where I probably had too much clutch and not enough power. Now that I have the power, its not as big an issue.
clip14
Jul 1, 2015 01:43 PM
kamakazy_kid
May 2, 2012 02:01 AM
catman78
18
May 7, 2011 06:13 PM
Wicked White
51
May 22, 2010 02:11 PM
antilag_200
19
Apr 21, 2010 06:02 AM
