Turbo Life
Old Feb 28, 2011 | 03:02 PM
EvoLeoIX's Avatar
Motor when out before my turbo did.
To the OP, new criteria to post:
Which turbo and model
Mileage
Boost Level
Which fuel
Driving habits
I demonstrate:
Stock IX turbo on ported ex mani
73,XXX
26psi on 93 and 31 on E85
pump and corn
street driven/// pedal meets floor maybe 4 times a tank
Old Feb 28, 2011 | 03:09 PM
TxEvo8's Avatar
130k miles on the stock 8 turbo. I've been running meth, then e85 for the last three years at 30psi with no problems except for a head gasket. The car has about 50 track days on it. (road racing)
Old Feb 28, 2011 | 06:48 PM
Sinister8's Avatar
I just wanted to see how reliable the stock turbo was and how the stock turbo's reliability compared to the aftermarket turbos such as garrett, precision, forced performance and etc.
Old Feb 28, 2011 | 06:59 PM
erald01's Avatar
the OEM turbo will last longer because it is build for the specific power, to flow so much air, tuned for so much power and on and on. When you usually put a bigger turbo it will flow more air, will rotate crazy rpm due to more air flow, more boost so the reliabilty factor drops a little bit. MHI turbos ( mitsubishi turbos) are the best turbos in the market and a lot of companies use their turbos. There has been a lot of engineering put on the design and reliability of their turbos.
EVO 4 life
Nov 15, 2016 07:11 PM
03upstatefire
Mar 3, 2011 03:37 PM
03BoostedVIII
Northwest Region
Jan 30, 2011 03:37 PM
TheTransporter
Lancer Aftermarket Forced Induction Tech
49
Dec 31, 2009 04:25 PM
EmperorX
Mar 26, 2009 06:04 PM
