Intercooler sprayer
Old Mar 4, 2011 | 03:55 AM
Boostme's Avatar
Intercooler sprayer
I'm curious do most if you guys take out the ic sprayer and reservoir? I just put in a ets intake and it's in the way a bit. I don't really use it either so I figure it's kinda pointless. What do you guys think?
Old Mar 4, 2011 | 04:01 AM
limp_noodle's Avatar
I installed an eta intake and the filter was hitting my resevoir. I never use it because I never found myself in a situation where I needed it so I pulled it all out.
Old Mar 4, 2011 | 05:21 AM
Boostme's Avatar
I'm thinking I am going to also. I don't really ever use it.
Old Mar 4, 2011 | 06:54 AM
Donkeypuncher's Avatar
pulled mine out too, dont use it and the switch is used for Dual Maps now for 93/E85
Old Mar 4, 2011 | 07:38 AM
Boostme's Avatar
that is a great idea, exactly how did you accomplish the duel map with the switch?
Old Mar 4, 2011 | 07:51 AM
Evoardo IX's Avatar
http://www.mrtrally.com.au/performan...IX-ICSpray.pdf
read that, then make your conclusions.
Old Mar 4, 2011 | 08:12 AM
KevinD from EvoDYnamics did it for me when he tuned my car. I think its just something offered in the software he uses.
Old Mar 4, 2011 | 08:22 AM
I don't road race so this doesn't apply to me.
If I want to run it at the strip I'll just mist on some water. That's the reason why I took mine out.
Old Mar 4, 2011 | 08:54 AM
J.J4ck0wsk1's Avatar
Just read the entire article and I have to say that's pretty awsome. The fact the ecu can control all of this is great. I don't have an Evo, but will definately make use of this when I do. Should any tuner be able to set this up or is it not all that difficult to adjust the settings using EcuFlash?
Old Mar 4, 2011 | 09:44 AM
e.v.o IX's Avatar
i pulled out the whole system in my evo...
Old Mar 4, 2011 | 09:56 AM
sirsol's Avatar
I also removed it from my 03, the system is nice but for daily driven, non-raced evos, I don't think its really necessary. Plus that's quite a bit of weight on the nose of the car, which is not too good.
It was handy for spraying down the IC at the drag strip between runs, but otherwise, I don't think I ever used mine.
Old Mar 4, 2011 | 10:02 AM
killercd4G63's Avatar
Veteran: Army
i put Kool-aid in my reservoir because both me and my Evo like grape kool-aid
Old Mar 4, 2011 | 10:40 AM
gsrboi80's Avatar
Tephra mods for ECUFlash can utilize the IC sprayer switch for map switching as well as well as having it spray for many different parameters like that article suggest.
ECUTek like that article mentions is done for.
As for the IC sprayer I chucked mine in the dumpster years ago
Old Mar 4, 2011 | 10:51 AM
AWD96's Avatar
Get a Buschur intercooler and call it a day. Or somehow rig the sprayers to spray to one side or the other, and douse peoples headlights with unnamed fluids while your at stop lights
Old Mar 4, 2011 | 11:43 AM
Would E85 make a difference in the need for this as well as a big badass intercooler? I hear that it burns so much cooler that there is less need for a huge intercooler much less a sprayer.
