Help, Do i need to replace my manifold?
Old Apr 1, 2011 | 04:29 PM
bryanf's Avatar
Originally Posted by sonicnofadz
Soak it with PB blast (while cold), drill a pilot hole and try using a high quality reverse drill bit (extractor bit). If you use a cheap one it will probably break, and you WON'T be able to drill it out after that. Your second option is to just drill the ****er out, or just replace the manifold (they are cheap).
This is probably your best bet I have done jobs similar to this at work and it works for me. Dont spend to much money trying to pull it though because you can pick up a manifold for cheap on the forums.
Bryan
Old Apr 1, 2011 | 04:46 PM
4RETECH's Avatar
As others have suggested, get an easy out.
Old Apr 3, 2011 | 12:25 AM
elementsk8erq's Avatar
Dont worry about it. It's just a heat shield bolt.
Old Apr 3, 2011 | 03:52 AM
sphinxof2006's Avatar
your going to have to sell your car sorry
Old Apr 3, 2011 | 10:42 AM
5LEEPERISAH23I's Avatar
that screw is just for the heat shield, i wounldnt worry about it. Just leave the heat shied off
Old Apr 3, 2011 | 11:47 AM
superz's Avatar
If you're not sure of what to do then maybe you should just leave the broken screw be. Using a drill can sound easier than it is, many times the bit won't be perfectly centered and cause the tap to break inside. I recommend not doing anything and leave it, it truly isn't a big deal, you'll forget about it soon enough!
Old Apr 3, 2011 | 12:18 PM
Sacevo9mr's Avatar
The heat shield isn't doing much, if you have the money rip it out of there, and check out xs manifolds they are great for the price and might actually give you some gains
Old Apr 3, 2011 | 12:37 PM
mmmmbst's Avatar
Veteran: Air Force
I'd leave it. Getting old rusted, heat soaked bolts out of almost any exhaust piece is almost impossible. just make sure you use anti-seize on the install of the other ones.
RalliartN
Mar 18, 2016 05:40 PM
alexand3r
Jan 18, 2016 01:12 PM
KarmaSRT
Dec 12, 2012 06:08 AM
icrnk
Oct 12, 2012 01:35 PM
Kevin Knight
For Sale - Part Outs
Aug 23, 2012 08:57 PM
