need help with mod
Old Apr 15, 2011 | 08:02 AM
sh26's Avatar
need help with mod
hello people, i need help with modification for my evo 8. my goal is to reach 430 whp. i already installed TBE, ARC induction box, hyper single cluch, 255 walbro fuel pump. now what should i do to reach to my goal.
Old Apr 15, 2011 | 08:05 AM
Frank120's Avatar
cams
mbc
do you have a cat?
are you on stock turbo?
Old Apr 15, 2011 | 08:10 AM
sharkm87's Avatar
do a search to see what people are running...and this topic has been talked about over n over.
do you even know where your car stands now power wise?
Old Apr 15, 2011 | 08:14 AM
Frank120's Avatar
i see where he or her? is coming from this forum cAN BE A B**** TO FIND STUFF ON SOMETIMES!! but i would also do a fmic with all new pipes
Old Apr 15, 2011 | 08:25 AM
sharkm87's Avatar
all i did was search for all threads with "reach" in the titles
https://www.evolutionm.net/forums/ev...nt-450whp.html
Old Apr 15, 2011 | 08:40 AM
sh26's Avatar
my 1 is turbo back exhaust wid testpipe. i already ordered fmic nd pipes from ams.Now i am confused about cams,injectorsand manifold,o2 housing ,turbo i should go for bcoz am running on stock turbo
Old Apr 15, 2011 | 12:17 PM
snapb1's Avatar
I'm running a filter, O2 housing, down pipe, test pipe-back exhaust, tune, fuel pump, FMIC, I/C pipe, cams, mbc @ 23 psi and only making ~310 HP (installed some stuff after she was dyno'd and it was hot as ***** when she was dyno'd). Its not gonna be easy/cheap to make 400+ HP w/ an 8 turbo...
Maybe going 10.5 hotside, manifold, injectors but doubt that'd put you at 400.
Old Apr 15, 2011 | 01:13 PM
JDMEVO206's Avatar
honestly i would have upgraded bolt ons n a stock frame turbo, cheaper than Intake mani. TB, cams etc
Old Apr 15, 2011 | 03:03 PM
EvoTeyn's Avatar
the fastest way is to get a new turbo. I have a TME turbo, LIC, short ram intake, cams, and a tbe, and some otha stuff...im pushing ~400
Old Apr 15, 2011 | 03:56 PM
chaotichoax's Avatar
searching ftw
check the dyno result section...see what mods people are using to achieve their power
closed...
junior1207
AWD Lancer (2012 +)
11
Dec 31, 2015 01:29 PM
Rktechevox
27
Apr 28, 2013 09:48 AM
screwnutbolt
Nov 20, 2011 06:47 AM
Blitz
Aug 14, 2009 12:11 AM
