Brake piston wont go back in
Old Apr 18, 2011 | 04:30 PM
cmydust's Avatar
im changing my brake pads today and im down to my last brake. I notice that brake fluid is over-flowing back up to the brake fluid container. I twist open the cap and re-tighten it. As i try to de-press the last piston, it wont budge. did i f something up or any suggestions?
Old Apr 18, 2011 | 04:44 PM
meckert's Avatar
Think thru what you said-- take the cap off, get some fluid out and depress the caliper piston which will raise the fluid level.. keeping the cap on at full and trying to depress the piston will get you know where.
Old Apr 18, 2011 | 04:52 PM
4RETECH's Avatar
I would have left the cap on the reservoir, opened the bleeder screw with a bleeder line and bottle on said caliper and then push piston back in. This way you are getting the crappy old fluid out of the lines.
But then again, I would flush them anyway when I was done.
Old Apr 18, 2011 | 04:53 PM
evo milk's Avatar
Take the cap off get a turkey baster and suck some of the brake fluid out, try not to get any contaminants in there. Probably should do a fluid flush after you're done.
good luck
Old Apr 19, 2011 | 12:58 PM
toyotabike's Avatar
1.Crack open bleeder screw.
2. Push piston back in. (allow fluid to come out of bleeder)
3.Close bleeder screw. Done.
Old Apr 19, 2011 | 01:49 PM
GTijoejoe's Avatar
Now that's good advice
Old Apr 19, 2011 | 01:52 PM
4RETECH's Avatar
Just don't get any air in there. That's why you use a clear hose on the end og the bleeder.
Raptord
28
Jun 22, 2018 08:06 AM
Montu
39
Sep 12, 2016 10:25 AM
PNWevoIX
14
Jul 19, 2016 06:19 AM
honda-guy
Apr 24, 2016 06:32 AM
Treyzian
35
Mar 31, 2016 10:36 PM
