Seibon Weights
Old Apr 18, 2011 | 04:43 PM
Trever007's Avatar
Seibon Weights
I spoke to Seibon on the phone today about some of there products weight. There fenders vary quite a bit from 5-6lbs. The Dry Hood (stock appearing) weighs from 3.8kg to 4.1kg. There wing comes in at 11.8lbs. There wet trunk is 16lbs. And there dry trunk is from 3.7 - 4.0kg. These weights come directly from seibon! Just be ware that the dry products need a clear coat! Also i was going to buy the dry trunk and hood as well as the wing untill i found out what there tolerances were. If the gap is less than 1/2" (yes .500") than it is within spec! If my car ever had a 1/2" gap i would kill myself!
Old Apr 18, 2011 | 04:53 PM
David Buschur's Avatar
I've had multiple carbon fiber parts, wide body kits, fenders, hood, trunk etc. I now have all stock body panels on my RS and I am happy. There is a lot of other places to save weight and with then stock panels the car looks good. There was ONE quality set of CF parts Ive seen, they were on the Sparco EVO, dry carbon. Strong as he'll and lightest Ive seen. I tried to buy them off the car, nope were not for sale.......owner didn't latch the hood, it blew open, not so nice now......
Old Apr 18, 2011 | 10:12 PM
chaotichoax's Avatar
robispec has the highest quality carbon parts you'll find with a reasonable price in this community...and the hood is actually lighter than the oem hood
Old Apr 19, 2011 | 07:11 AM
Unless something has changed, you are incorrect. His may very well be the lightest but too light for street use. I can't tolerate a hood that droops down when the prop rod is holding it up. I can't stand a trunk lid that if you push on it your fist will crack it.
Old Apr 19, 2011 | 03:47 PM
not sure what you are saying I'm incorrect about
never said they were good for street usage...I just said they are light and fit well
Old Apr 19, 2011 | 07:02 PM
Craig King's Avatar
I've heard a couple of times that the Seibon CF hood is actually heavier than the stock hood.
Old Apr 20, 2011 | 06:33 AM
OK, yes, they are light and do fit well. Sorry.
Old Apr 20, 2011 | 07:22 PM
Trever007's Avatar
The "WET" Seibon hood is heavier than the stock (aluminum) one. The "DRY" seibon hood is lighter. They told me the "DRY" hood weighs 3.8kg - 4.1kg (8.4lbs - 9.0lbs). The stock (aluminum) hood weighs 20.2lbs as per Buschur's site. They also have a Carbon hood weight listed but he doesent say what brand. Maybe he could chime in! But also just for all your info the "DRY" hood still needs a clear coat which will add a little weight and it also costs $2,400! Is 11.2lbs worth $2,400? Ill let you decide!
Old Apr 20, 2011 | 07:34 PM
no sorry needed David, just trying to make sure we were on the same page
Hiboost
75
Dec 4, 2019 05:09 PM
Jakartaboost
Oct 5, 2013 09:56 AM
Synaptic3e
EvoX 'For Sale' Exterior Styling
Dec 30, 2010 07:43 PM
CVR Motorsports
233
Oct 17, 2009 03:47 PM
9sec9
Mar 15, 2009 09:32 PM
