Help with UICP
Old Apr 19, 2011 | 07:40 PM
clubEVO93's Avatar
Help with UICP
Ok so heres my story i bought my car(IX MR) in may of 2010. and i knew that it had problems. It had a CEL and garbage truck exhaust on it. and leaking gaskets all over the place. So i got it home and inspected top to bottom. full fluid change. When i bought it. it would only boost to 15LBS at WOT. And i knew that wasnt good. So i parked it. until december when i had my mind set to get to the boost leak or something. So as i start to break it apart I pull the turbo out and see the j-pipe bent and not sealed completely on the back side. So i call up and get a replacement asap. also thats when i ordered my turbo xs tbe megan o2 housing, ets upper/mini battery and lower pipes, and mistimoto FMIC, walbro, after installing everything besides the upper and walbro. I took it for a spin for the first time since i parked in last september. And well it was boosting fine. And this brings me to my problem. after i put it back together, stock uicp on. the couple blows off under Wot. And so i went and put an ets t-bolt clamp on thinking it wouldnt happen again. I was wrong it blew off again. whats wrong?
Old Apr 19, 2011 | 07:44 PM
binky's Avatar
Here's some things to try:
1) Use hairspray to hold the UICP pipe on more securely.
2) Tighten the T-bolt clamp more.
3) Use 2 T-bolt clamps.
I had trouble understanding your post about whether or not you were using an ETS UICP or the stock UICP?
-Bink
Old Apr 19, 2011 | 08:20 PM
clubEVO93's Avatar
Im using the stock upper
Old Apr 20, 2011 | 05:03 AM
clubEVO93's Avatar
Where should i put the hairspray? on the TB or inside the coupler?
-Bink
Old Apr 20, 2011 | 05:33 AM
binky's Avatar
The issue you could be having is that the stock UICP expands a lot under boost, a harder material might be needed to keep it from popping off. i.e. a new metal UICP.
I would do it on both, just make sure you don't get an over spray inside the TB.
-Bink
CN9Adaiski
11
Jan 9, 2014 08:41 AM
ProjExtremis
Jul 12, 2013 06:28 PM
Guitarplyr
28
Oct 20, 2011 05:41 PM
Snipingdude
May 4, 2011 04:19 PM
Chemwarrior
May 12, 2008 05:34 AM
