This is why you should run a catch can
Old May 9, 2011 | 06:20 AM
TIBOevo's Avatar
Originally Posted by MJ23FE
So that particular type of fluid collected in the can is specific to e85 you'd say? I'm used to seeing the grimy more sludge-like fluid/substance that comes from the ports.
How often do you recommend checking the cans, and is it different depending on the fuel you use?
-Jalal
i check mine once a month. i get the same watery stuff and i run 93oct fuel. pretty much anything that starts off cold and then heats up will make condensation. think of your engine as a glass of cold water on a hot sunny day. so as the engine warms up, the water/oil vapors will need to escape some where. so we run a catch can so that those crappy vapors dont get dumped back into the intake tracks or the ground environment.
Old May 9, 2011 | 06:41 AM
TopSpeed's Avatar
Originally Posted by neonglh
It would be neat to see what it is. My theory it is from running E85, but I can't say for certain. All I know is that every hundred miles or so of hard driving, I drain that much from my car. I am sure it wouldn't ruin my engine going through, but everything stays that much cleaner by properly venting it out of the system
I get the same exact thing from running E85 as well.
Old May 9, 2011 | 06:44 AM
evilempire76's Avatar
Can you post some pics of your catch can setup? So are you running one can or two?
Old May 9, 2011 | 07:02 AM
neonglh's Avatar
Me? The can is in the picture on my first post.
It's one can, mounted on the firewall with a breather filter on the top. AN fittings on my valve cover connect line from the valve cover to the can.
Old May 9, 2011 | 07:03 AM
TopSpeed's Avatar
Here's mine..
Old May 9, 2011 | 07:27 AM
neonglh's Avatar
And mine:
Old May 9, 2011 | 07:34 AM
TopSpeed's Avatar
That is one CLEAN engine bay!
Old May 9, 2011 | 10:44 AM
neuspeed's Avatar
I need to install mine...I also run E85 hmnn..
Old May 9, 2011 | 02:08 PM
ta ace's Avatar
i put a -10 fitting in my valve cover and ran a big hose to under the car and the one on the back i also vta and i just let them vent to atmosphere...
no dumping required
but when i idle in place for 5+ mins it will look almost like my ac was on lol leaves a lil puddle
lol 2.4lr
Old May 9, 2011 | 02:47 PM
neonglh's Avatar
no dumping required
lol 2.4lr
So then any junk in the atmosphere can just get sucked in (dirt, dust, etc..) at any time? That's not that smart, unless you have filters on them.
Old May 9, 2011 | 02:55 PM
LakerRaider's Avatar
i dont catch anything from my catch can in between the valve cover and the intake...But when I woul check the intake tract before installing the can, there would be lots or gunk. I havent checked it after the install though (about 500 miles ago) its a saikou michi btw
Old May 9, 2011 | 03:00 PM
KX250Fmotoracer's Avatar
Ethanol is hygroscopic, is it possible that you're getting water vapor out of the E85?
This hasn't been found on 100% pump gas engines?
Old May 9, 2011 | 03:07 PM
mdsevo06's Avatar
I've been running E85 since Aug. 2008 and have never had this is my CC. Maybe a cap of Oil, no water. I DD it and garage it at night, not sure if that makes a difference.
Old May 9, 2011 | 03:17 PM
raiceboi697's Avatar
mark, is there any way you can take a custom picture for me? im trying to see if my catch can idea will work before i drop my engine in. I just need to know how much space between the firewall and the intake manifold from the intake manifolds lowest point.
Also thanks for the heads up on e85 cars and catch cans as im switching to e85 this year
Old May 9, 2011 | 03:28 PM
mrboost05's Avatar
Originally Posted by tsidrift1
I really need to grab some stm an fittings and get a catchcan.
I just ordered mine from them last friday i also ordered there dip stick that has the -6 fitting welded in i plan on running the drain from the can back to that fitting ive never seen anything like that come out of my cans that looks pretty clean compared to what normally comes out of my cans so its gotta be E85 related i have a few wiring questions neonglh but ill pm you those.
