This is why you should run a catch can
Old Mar 6, 2013 | 10:04 PM
  #151
tscompusa's Avatar
Originally Posted by evodan2004
here is the crap i get. its mostly oil.
http://www.youtube.com/watch?v=jBPDQXWarxo
this is after 1 or 2 pulls at the drag strip. when i drive normal i get the crap you guys see/very little oil.
That's a perfect example of a failed ventilation system. Its dumping your oil right into the can. Its because you tapped into somewhere on the valve cover that doesn't have proper baffling to stop the oil from entering into the lines then into your can.
The only fix really is to baffle the part that's pushing the oil, which is whatever hole you drilled that wasn't initially there from the beginning.
The actual catch can itself is doing its job relieving pressure, but the way your valve cover is tapped needs addressed more with proper baffling. This is why i only enlarged the factory hole that already existed, because if you inspect the valve cover thoroughly you will note there's tons of baffle where the existing factory hole is.
Old Mar 30, 2014 | 03:34 PM
  #152
Evolution7GSR's Avatar
I installed the buschur unit and just ran a line with a valve on the bottom to empty it and every since i am getting a lot of smoke coming out the breather filter that sits atop the catch can. Any ideas?
Old Mar 31, 2014 | 08:58 AM
  #153
jrainwater's Avatar
Originally Posted by TopSpeed
Here's mine..
That's a sweet set up. Props man.
Old Apr 29, 2014 | 10:28 PM
  #154
Galaxshiel's Avatar
ok guess i should run a catch can for safety
Old Apr 30, 2014 | 09:14 AM
  #155
kinje's Avatar
Catch cans are well worth it!
Old Jun 6, 2014 | 06:27 PM
  #156
foxbear2277's Avatar
So what was the reason why so much oil was getting into the catch can? Was it because the valve cover crankcase ports/port was installed in a non/poorly baffled spot on the valve cover?
Old Jun 8, 2014 | 02:39 AM
  #157
wowzers's Avatar
How does the STM oil catch can connect to the engine?
Old Jun 8, 2014 | 03:08 PM
  #158
Mortard's Avatar
I'm waiting to finally finish up my build and tune, then I'm gonna by one!
Old Jun 16, 2014 | 09:40 AM
  #159
edgeofautumn9's Avatar
That seems like a over the top amount of fluid, but I've never run E85. Womp Womp
EvoooB
May 1, 2016 01:54 PM
RussellM
MitsubishiParts.net - WA
Jul 20, 2015 04:48 PM
buzzzin_IX
Jun 23, 2015 07:39 PM
black_beauty
Jan 27, 2014 02:55 PM
stck_trbo_mnstr
Mar 31, 2012 12:10 PM
