This is why you should run a catch can
Old May 8, 2011 | 11:29 AM
neonglh's Avatar
Running E85 and Brad Penn oil, I get this much fluid in my catch can after about 100 miles or so. This would all end up gunking up everything if it wasn't for a good catch can
Old May 8, 2011 | 11:42 AM
fabcas311's Avatar
what catch can is that??
Old May 8, 2011 | 11:43 AM
autotechnica's Avatar
put a little protein powder in there and have a high octane shake!!!
neonglh's Avatar
It was custom fabricated at STM for my car. It's their normal catch can, just adapted to fit on my firewall, right near the tranny.
Old May 8, 2011 | 11:47 AM
MJ23FE's Avatar
Damn! Where exactly did that pull from?
-Jalal
Old May 8, 2011 | 11:49 AM
neonglh's Avatar
-Jalal
From the crankcase, it's the normal ports on the drivers side, and rear side of the valve cover.
Old May 8, 2011 | 02:55 PM
Johnr352's Avatar
That is a LOT of fluid!
There's an inappropriate joke in there somewhere, I just can't think of it yet.
Moroso has adpated their new catch can to the Evo X (they used my car to do it). It's big like that and extremely well made.
Old May 8, 2011 | 07:01 PM
binh's Avatar
I get a lot of the same watery juice from my catch can as well with e85.
Old May 8, 2011 | 07:47 PM
FERNO's Avatar
Time to research catch cans!
Old May 8, 2011 | 07:49 PM
tsidrift1's Avatar
I really need to grab some stm an fittings and get a catchcan.
Old May 8, 2011 | 08:56 PM
MJ23FE's Avatar
So that particular type of fluid collected in the can is specific to e85 you'd say? I'm used to seeing the grimy more sludge-like fluid/substance that comes from the ports.
How often do you recommend checking the cans, and is it different depending on the fuel you use?
-Jalal
Old May 8, 2011 | 11:10 PM
My03evo's Avatar
Damn I always thought it would be a gunky milky brown liquid not a watery fluid unless thats helluva alot of condensation which does happen going from hot to cold all the time but damn thats alot
Old May 8, 2011 | 11:42 PM
Ian0611's Avatar
You outta send that to a lab and have it inspected just to find out exactly what that is.
Old May 9, 2011 | 02:59 AM
testa corse's Avatar
that's a lot of fluid catch can did a good job
Old May 9, 2011 | 06:17 AM
neonglh's Avatar
It would be neat to see what it is. My theory it is from running E85, but I can't say for certain. All I know is that every hundred miles or so of hard driving, I drain that much from my car. I am sure it wouldn't ruin my engine going through, but everything stays that much cleaner by properly venting it out of the system
