This is why you should run a catch can
Old May 9, 2011 | 03:34 PM
  #31
06MREvo's Avatar
Originally Posted by autotechnica
put a little protein powder in there and have a high octane shake!!!
^^hahah!!
Thanks for posting this OP...shows everyone what kind of crap ends up in a catch can...I wouldn't want that going back in my motor...
Old May 9, 2011 | 03:57 PM
  #32
neonglh's Avatar
Originally Posted by raiceboi697
mark, is there any way you can take a custom picture for me? im trying to see if my catch can idea will work before i drop my engine in. I just need to know how much space between the firewall and the intake manifold from the intake manifolds lowest point.
Also thanks for the heads up on e85 cars and catch cans as im switching to e85 this year
I can do that for you. I have the Drivin Innovations manifold, is that what you run?
Old May 9, 2011 | 04:11 PM
  #33
mrboost05's Avatar
Originally Posted by 06MREvo
^^hahah!!
the stuff that comes out will do your motor no harm if you ran it back thats been proven but it also dosent hurt to empty your can if thats what you wish to do i am still amazed at the tiny size of the cans we run in our evos compared to other makes and models.
Old May 9, 2011 | 04:13 PM
  #34
raiceboi697's Avatar
Originally Posted by neonglh
I can do that for you. I have the Driven Innovations manifold, is that what you run?
YEZZIR!! Large plenum with stock TB
Old May 9, 2011 | 04:25 PM
  #35
neonglh's Avatar
I'll measure for you tonight, when I'm out doing some work
Old May 9, 2011 | 04:36 PM
  #36
Roadrunr's Avatar
Are you running any PCV system with your catch can ? If you run a small vacuum to your PCV port in the valve cover, the moisture will be pulled from the engine and burned in the motor with no issues.
Don
Old May 9, 2011 | 04:50 PM
  #37
neonglh's Avatar
Don
I'm fine with just draining my can, instead of having it go back in the motor.
Old May 9, 2011 | 05:26 PM
  #38
My03evo's Avatar
Exactly, me too...Might not do "harm" but sure as hell doesnt do good, and I dont want no moisture/gunk/unburnt fuel/blowby going into my oil if it doesnt have to, not when the oil is the blood of your engine, would you want crap mixing in with your blood in your body? I know I wouldnt
Old May 9, 2011 | 05:47 PM
  #39
EvoJoeIX's Avatar
not to be off topic, but how did you wire tuck the engine bay like that? looks awesome
where do you put all the fuse boxes and stuff?
Old May 9, 2011 | 06:43 PM
  #40
neonglh's Avatar
Long build thread in the Show and Shine. Search for my name and read 20+ pages
Old May 9, 2011 | 06:44 PM
  #41
forc3 f3d's Avatar
he has a whole build thread of relocating everything, on here.
Old May 10, 2011 | 06:25 AM
  #42
ta ace's Avatar
So then any junk in the atmosphere can just get sucked in (dirt, dust, etc..) at any time? That's not that smart, unless you have filters on them.
the way a pcv valve works is it only goes out not in...?
like a check valve
Old May 10, 2011 | 06:31 AM
  #43
neonglh's Avatar
I took some pictures and measurements this morning, but it was tough. I will PM them to you in a few. It seems like there is up to 4" at the widest point at the bottom of the manifold, once you get under the strut bar mount plate on the firewall.
Old May 10, 2011 | 06:37 AM
  #44
evilempire76's Avatar
like a check valve
Actually the system goes both ways. Are you still running or do you have a check valve?
I still need to hook something up for my valve cover to intake manifold side. I'm gonna try to get something setup this week.
Good info found in here:
http://www.dsmtuners.com/forums/arti...cv-system.html
Old May 10, 2011 | 07:26 AM
  #45
got the PM thanks!
