This is why you should run a catch can
Old May 18, 2011 | 04:21 PM
  #121
polish_pounder's Avatar
Originally Posted by neonglh
Sure, I use the factory ports, I just have the AN fittings pushed into them. You can very well use the factory plugs, you just have to use zip ties or hose clamps to go over the hose in that case.
Ok that's good by any chance do u have a picture of what ports I hve the weapon r catch can so I have two hoses but I don't know where they go ha
Old May 18, 2011 | 04:37 PM
  #122
boostedwrx's Avatar
Originally Posted by boostedwrx
OP/neonglh - does you car sit for long periods like mine? Although garaged, my garage isn't insulated so stuff tends to rust and moisture gets into my exhaust, etc.
bump
Old May 18, 2011 | 07:08 PM
  #123
neonglh's Avatar
bump
My car does sit for long periods of time, but I have a pretty well-insulated garage. Also, everything on my car is stainless, aluminum, or coated, so I don't have any rust on anything, not even bolts!
Old May 18, 2011 | 07:09 PM
  #124
neonglh's Avatar
I have a picture posted on page 2 of this thread I believe!
Old May 19, 2011 | 10:07 PM
  #125
EvoDan2004's Avatar
bump
i have that issue. i never drive in the winter months or the rain but being my garage get humid as hell in the summer my cars underside looks like its 30 years old
Old May 20, 2011 | 09:16 AM
  #126
boostedwrx's Avatar
^ Sorry I more meant that tools and other sorts of objects have been starting to rust in my garage. However my car has not rusted. Living in Seattle has its moments.. I was maybe thinking for us running E, and those of us who let the car sit for long periods of time, maybe some of the fluid were draining is fuel/water. Although I took the torch to my fluid and it burned/evaporated.
Old Jul 31, 2011 | 04:47 PM
  #127
gymnasty's Avatar
Hello I Want to hear what you guys think is a good, respectable, durable catch can. I'm in the business of looking to buy one don't know where to start looking or which brands make them. I looked at the buschur racing one any thoughts on that one? TIA
Old Aug 1, 2011 | 03:39 AM
  #128
Roadrunr's Avatar
The topic of this thread should be " This is what happens when you disconnect your PCV Valve "
The reason these people are experiencing large amounts of H20 in their catch cans is from the lack of a operating PCV system to remove the condensation in their motor. Water Vapor is a by product of the combustion process. Under boost the crankcase is further pressurized by the higher prssure which is pushed past the rings. Plus every time you start your motor you are adding more moisture to your non PCV'ed engine. After many hot , cold cycles you have what is displayed in their catch cans.
PS. On a daily driven vehicle, I would not recommend operating it with out a pcv system to purge the motor of the moisture.
https://secure.buschurracing.com/cat...oducts_id=1268
I feel that this is the best with it's return port to the oil pan doubling as another pressure relief under boost. Therefore you do not have to drain the tank. If you run the PCV line to the old pcv fitting on the intake manifold and T off of it to the top port on this catch can you still pull a vacuum on the valve cover and the catch can when not on boost. I use a Krank Vent
http://www.et-performance.com/index.html
directly off the manifold thus allowing the old pcv port on the valve cover to empty into the can when under boost. The can will only allow the moisture to be drawn into the combustion chamber which is harmless to your engine.
Don
Old Aug 1, 2011 | 09:55 AM
  #129
tscompusa2's Avatar
i did probably 150 pulls in my car the last week and i have not a droplet of oil or fuel in my catch cans.
heres the route i went; http://oi51.tinypic.com/2a5dkwg.jpg with a 5/8" fitting from the valve cover to intake, and standard from pcv to can.
more info here; https://www.evolutionm.net/forums/ev...re-issues.html
i still use a spring i got at ace hardware to secure the dipstick just in case, but i forgot to reconnect the spring the other day and did like 40 pulls and the dipstick didnt budge. the only thing most people need to do is just drill out a bigger relief hole in their valve cover and that will cure all the crankcase issues they have.. you could even run the line to the ground, you dont even need the catch cans really.. if you drill only where the old side port is, the valve covers baffled enough to stop all oil sloshing. the factory pcv system works fine once you allow the valve cover to breath better out the side. atleast for my driving habits.. which is mostly straight line WOT.
Old Aug 1, 2011 | 06:38 PM
  #130
tmaddox's Avatar
and of course to help reduce the fluid don't run E85. That stuff is a magnet for water.
Old Aug 1, 2011 | 08:03 PM
  #131
Nohatn's Avatar
put a little protein powder in there and have a high octane shake!!!
LoL i would add vodka and have an insane Vodka Toxic ..
Old Aug 2, 2011 | 02:09 PM
  #132
gymnasty's Avatar
So from what I've gather one catch can would be enough I don't need to have two? As long as it has 3 ports and 1 vent on it your good? If I'm wrong please someone correct me. I'm thinking of fabricating my own catch can or buying a buschur one.
Old Aug 2, 2011 | 02:13 PM
  #133
boostedwrx's Avatar
^I think it depends how much oil gets tossed out your valve cover side port. I barely get anything so I just run a breather filter. I've seen others like EvoDan that run a can there because sludge is collected. My 2c anyway..
Old Aug 2, 2011 | 03:41 PM
  #134
JDMCT9MR's Avatar
Holy crap! I'm glad I have a catch can on my car.
Old Aug 2, 2011 | 03:51 PM
  #135
IbeBOOSTIN's Avatar
It would be neat to see what it is. My theory it is from running E85, but I can't say for certain. All I know is that every hundred miles or so of hard driving, I drain that much from my car. I am sure it wouldn't ruin my engine going through, but everything stays that much cleaner by properly venting it out of the system
I like this moroso catch can here I come
