Evo 8 idle issue
Old May 29, 2011 | 05:29 PM
Clarkie1685's Avatar
Evo 8 idle issue
So we did some work on my evo today, and now the car will start and then it just dies out. At one point you had to give the car gas to just even get it to start. But now, you can rev it up a little bit, start the car, and then once you let off the gas it just dies. We've been working all day on the system, and can't figure out anything. Any suggestions ?!!
Old May 29, 2011 | 08:07 PM
SwiftyMcVae's Avatar
subscribed.. I test drove an 8 that im interested in buying, this weekend. And it had the same weird issues.
Start, run normally. Then start idling funny, then die off. start up again no problem.. weird.
Old May 29, 2011 | 08:13 PM
4RETECH's Avatar
Do you still have a MAF system? Did you do anything with intercooler piping or injectors?
Maybe try a boost leak test.
Old May 29, 2011 | 08:14 PM
06RedRalli's Avatar
MAF Plugged in?
Old May 29, 2011 | 08:20 PM
dotman05's Avatar
Did you check for any codes?
Old May 29, 2011 | 10:00 PM
still running maf system, running about 40 psi the bov was frozen up and i rebuilt that also ran a boost leak test and no leak showed. im thinking possibly a intake manifold gasket or possibly a bad iac. the car builds all 31 pounds and runs like a charm the only problem im seeing is it will no longer idle. sorry for bad grammar i typed from my phone.no codes shown.
Old May 30, 2011 | 07:14 PM
thats funky. Would be cool if you could post a video of it. while the weird idle is in motion
Old May 30, 2011 | 07:34 PM
BLK_EvIL's Avatar
Sound like classic IAC going bad same thing happend to mine. You can test the resitance between the pins on the IAC or you can even pull it out of the TB still pluged in turn the key to acc and have someone see if the plunger moves also check the teeth on it they tend to wear down and break being plastic. Ebay has some really cheap ones got mine used for $45 new one at dealer is around $300.
Old May 30, 2011 | 07:35 PM
4RETECH's Avatar
Amazon has them new for $160.
Old May 31, 2011 | 08:58 AM
Delfast's Avatar
kinda sound like bad IAC to me. let us know what you find
Old Jun 1, 2011 | 09:41 PM
iac was good Thanks black evil for the info on how to check it. while in the process i noticed all i had was a vacuum hose that had came off the throttle body no problems since thanks all.
Simon Pugmire
Mar 23, 2017 06:13 AM
STIU2SLO
Feb 14, 2017 02:21 AM
Nastypants
Sep 27, 2016 08:24 AM
evo_gremlin
52
Jan 26, 2012 10:58 AM
yikez
Sep 6, 2008 03:44 PM
