Warm engine after rebuild (in engine brake in)
Old Jun 8, 2011 | 07:49 AM
Mauricio Evo IV's Avatar
Hellos Guys.
One again I have a question for you.
I have a complete engine rebuild. Iīm in engine brake in right now, I the motor only have 500Km on it (312 miles) not WOT and nothing...all was ok, not issues.
Last weekend I traveled like 100 miles and on a slope the engine temperature went up... this happened three times to reach the city...
Right now, we tested for leakage of engine compression and nothing. the car was like three months out. If there is not leakage of engine compression, could be the radiator, I donīt know. But wanted to know what other problems may feel these engines warming???
What could be the cause of warming on slopes??? and in traffic all is fine....
Old Jun 8, 2011 | 08:14 AM
barneyb's Avatar
With the engine cold, remove the radiator cap, check if the radiator is full and report back.
Old Jun 8, 2011 | 08:33 AM
Hi, when the engine was warming, I saw its was throwing the water but did not see where! I put more water for continue my trip. When was cold the radiator need more water. the plastic deposit was full of water.
Old Jun 8, 2011 | 08:37 AM
barneyb's Avatar
Head gasket leak
Old Jun 8, 2011 | 08:41 AM
Head gasket leak
Like I say before, I did the leak test engine compression and nothing, everything is in order... so, can not be the head gasket.
Old Jun 8, 2011 | 08:55 AM
barneyb's Avatar
With a new build you should have used new hoses. So, if we can eliminate that, and the radiator is good, the over temperature events occurred during boost so cylinder pressure was high. This isn't something testing would reveal. Pushing water to the overflow jug is the classic symptom of a blown head gasket on this engine.
Old Jun 8, 2011 | 09:00 AM
L@Ncer06's Avatar
Its the head gasket happend to a friend of mine we did the test and everything checked out but it was still warming up finally decided to take the head off an see what was going on and it was small tares in the head gasket. oh also check the torque on the head studs
Old Jun 8, 2011 | 09:11 AM
Hi.. So did you leak testing engine compression and all was finel?? I have to worry about....
Old Jun 8, 2011 | 09:11 PM
1UpMoto's Avatar
do a leak down test.
Old Jun 8, 2011 | 10:01 PM
Boostedx11's Avatar
Pull the head or check your cylinders, what color is the coolant or your oil? any discoloration?
Old Jun 9, 2011 | 06:50 AM
It was the fu#%&ing radiator!!!!! The radiator was almost new. Its a PWR aluminium radiator. I never imagined it would have been the radiator. itīs went blocked out and inflated, so for that the warming.
Old Jun 9, 2011 | 07:33 AM
evo8426's Avatar
What was wrong with the radiator?
Old Jun 9, 2011 | 08:10 AM
As they told us that the inner tubes were inflated and obstructed the passage of water... Why?? I donīt know!
The conclusion is that the radiator does not work...
What about the Mishimoto brand????? I need a new one!!!
J8dailo
Mar 1, 2017 10:08 AM
Estorilblau
Lancer Troubleshooting
Mar 14, 2012 12:39 PM
TEV
Aug 5, 2010 07:18 PM
*02Lancer*
Lancer Engine Tech
Apr 20, 2009 07:54 AM
WhiteEvo05
11
Sep 1, 2005 05:51 PM
