RPMS rise high with ac on
Old Jul 3, 2011 | 02:35 PM
nytalonTSi's Avatar
I've noticed while idling if I click the ac on, the rpms shoot up from 1k to 2k or more then settle back.
Usually I know the rpms will rise about 200-300 when the compressor is working then settle back down this will tell you the IAC is functioning.
I did a BLT today and she holds boost no problem. But am still having boost/vacuum leak symptoms
IAC failing? It has 85k on it.
Old Jul 3, 2011 | 11:25 PM
TunerHead24's Avatar
its normal the ecm compensates for the extra load from the a/c compressor by raising the rpm.
Old Jul 4, 2011 | 12:47 AM
nytalonTSi's Avatar
Yeah I know it's normal, but it shouldn't rise to 2k. It used to only rise no more then 300 rpms.
Old Jul 4, 2011 | 01:04 AM
blackoutVIII's Avatar
I noticed that sometimes my RPMs just rise after I rev my engine up and it will hold around 3k-4k in neutral until I put it in gear again with the clutch in for a few seconds, then it goes back to normal. Anyone have the same issue? It also did it to me oncve at a redlight when I was slowing down. It seemed to me at first as if the throttle cable was stuck, but i checked that out and it moves freely. Any advice?
Old Jul 4, 2011 | 09:36 AM
HaVoC187's Avatar
Mine had really erratic idle with ac turned on but it almost completely went away after I made myself a 8-point ground kit.
Check out this thread:
https://www.evolutionm.net/forums/ev...-kit-20-a.html
Sheasta
Mar 8, 2014 11:28 AM
1fast97gsx
Feb 16, 2014 04:32 PM
BlackDismay
Dec 12, 2011 06:05 PM
fabcas311
10
Jun 30, 2011 12:39 PM
RobDogg
Aug 5, 2006 04:43 AM
