Tial 44mm mvr issues...
Old Jul 4, 2011 | 05:50 PM
yellowevo82's Avatar
well i just installed my brand new tial mvr 44mm and its like im hitting a brick wall at 8lbs of boost.. what could be my issue??? i installed the springs for 1.4bar which is 20psi .. as soon as i go to get on the boost my car hits fuel cut
motor: built
turbo: hta86 /ron shearer t3 manifold / factory facing not forward facing
ecu: aem ems
ignition: buschur cdi
fuel: br double pumper/ fic 2150's/stm fuel pressure regulator
Old Jul 4, 2011 | 08:44 PM
stumped ya all?
Old Jul 4, 2011 | 10:04 PM
EvoJoeIX's Avatar
if your hitting fuel cut, sounds like a tune issue
Old Jul 4, 2011 | 10:20 PM
emery tuned it at stm there should be no tune issues with just installing a new wastegate..
Old Jul 5, 2011 | 12:54 AM
ahmed718's Avatar
Tune problem more than likely
Old Jul 5, 2011 | 09:51 AM
once again its not the tune.. i had a tial on my car last week with zero issues...
Old Jul 5, 2011 | 10:30 AM
EvoJoeIX's Avatar
you said you JUST installed the mvr and your hitting fuel cut. now your saying you had it on there for a week and it was fine?
if emery tuned the car, call him and ask him. fuel cut is messed with in the ECU, so obviously it is a tune issue
Old Jul 5, 2011 | 10:38 AM
no never said i had that same wastegate on my car last week.. i had an old version tial 44mm on my car prior with zero issues.. now i replaced that with a mvr and i have the issue..
Old Jul 5, 2011 | 10:42 AM
EvoJoeIX's Avatar
oh okay thats what i thought you meant.
were you using the same spring pressure on the old one as your new one?
what are you using to control boost?
Old Jul 5, 2011 | 11:19 AM
yes 1.4 bar... hallman pro
Old Jul 5, 2011 | 11:22 AM
do i plug up this port as well follow the black arrow..
Old Jul 5, 2011 | 11:24 AM
TiALSport's Avatar
is it 8 or 19psi you are hitting cut because you've told me two very different boost levels.
manual boost controller? leave both of the top ports open
Old Jul 5, 2011 | 11:26 AM
sorry dint update the thread.. got the car to 19lbs yesterday and thats when i have issues... so i have it right now then i plug all the bottom air ports not used , leave the two top open.. brb going to take the car for a spin
Old Jul 5, 2011 | 11:47 AM
not fixed still hitting fuel cut.... 8lbs is the max i can get the car to ... do you think the 1.4bar is to big or not enough?
Old Jul 5, 2011 | 12:23 PM
TiALSport's Avatar
i think you have one of the following issues:
something in the ECU changed
leak in the boost gauge line
leak in the signal line to/from gate
fuel cut is ecu controlled - if you are only getting 8psi there is no way the computer would cut you off
can you hear the gate opening?
