Stripped manifold bolt
Old Jul 7, 2011 | 08:25 PM
spyderx's Avatar
I have this last bolt behind #1 runner on a tubular manifold that's close to being stripped and I can't get to it with anything but a open 12mm wrench. But it only strips it further. There is no room to wrap a closed end wrench.
I'm thinking I'll have to surgically cut the bolt with a Dremmel and may have to replace the threaded stud...
Anyone else dealt with this removing manifolds? Thanks
Old Jul 7, 2011 | 08:28 PM
craig05evo's Avatar
ouch thats no fun. Any chance you can get an american size on it? try a 15/32 or 1/2 that might do the trick.
Old Jul 7, 2011 | 08:58 PM
2slow4now's Avatar
Last resort use a small grinder and whittle the nut down to the threads and you may be able to get it off without damaging the stud. You got it right precision surgical grinding with risk.
Have you used some wd40 and heat the PP out of it?
Old Jul 7, 2011 | 11:45 PM
3K's Avatar
3K
Did you try a swivel head ratchet? That's the only way I could reach those bolts.
Old Jul 8, 2011 | 07:31 AM
Danner's Avatar
Ive seen people weld nuts onto the end of stripped or broken studs and then just cranked them off that way. You can safely weld on car if you know what your doing.
Old Jul 8, 2011 | 07:36 AM
cfdfireman1's Avatar
"Stripped manifold bolt" or head rounded? bolt and a threaded stud? Am I the only one that's confused here?
Old Jul 8, 2011 | 08:14 AM
clubEVO93's Avatar
I welded mine back on. But its not a long term fix. Get the fp stud kit and repair it.
Old Jul 8, 2011 | 06:46 PM
spyderx's Avatar
I should of said stripped nut. I managed to separate the turbo from manifold. I gave up on tHe last nut and left the manifold on. Just shipped the IX turbo to FP for HTA green. Ill be now selling my brand new ToxicFab mani. Now about that broken DP bolt in my O2 housing...
Thanks guys!
kiddsm95
Apr 23, 2013 10:47 AM
apiazza2010
Sep 6, 2012 08:51 PM
motocooney
May 4, 2011 07:33 PM
Ray Knight
Jul 24, 2009 08:36 AM
4TUN8
31
May 4, 2008 03:50 PM
