Mods That Need IMMEDIATE Retune
I bought the car a month or so ago and am switching out quite a few parts prior to doing a duel map E85 tune. I want to swap out what I can to avoid install charges and drive the 100 miles and get it tuned.
Which parts can I change and safely make the drive to get it tuned?
Turbosmart MBC ---> HOA Imports 3-port boost control solenoid
Stock Injectors ---> PTE 1200cc Injectors
Cobb SF Intake ---> AEM Intake system
Megan Manifold ---> OEM Manifold
OEM Fuel Pump ---> Walbro 255lph High output fuel pump
I would do everything except the 1200cc injectors you can do that once you get to where your going. I'm getting mine tuned tomorrow and I'm driving it about 20 miles and I have cams, valve springs, Walbro and a bunch of other stuff and also 1000cc injectors. Just stay out of boost and take it easy.
Bryan
Bryan
Bryan
Bryan
The 3-port will be set to whatever WGDC is in the map, so if you install the 3-port I would advise you to not go WOT as you don't know how much boost you'll end up with. Injectors you definitely can't do without a retune, the rest should be fine.
I did my injectors today and took my time it was about a 1 1/2 hours of work. The hardest thing about it is that it's such a tight space. You need a 12mm and 10mm with small extension, pliers and a little oil for the o rings. Also some rags and a very small screwdriver I think that's it. If you don't mind me asking where are you getting tuned at??
Bryan
Bryan
Bryan
Bryan
I say let the shop do the injectors.
I let my shop do it, and it turned out one came with a faulty seal.
Since it was their install, they took care of it: no worries.
PLus, poking about under the hood of a car that you just drove, in summer heat, trying to reach over a hot engine, and groping around hot things that have ignitable fuel isn't 100% good.
Other than that, the walbro 255 is a direct drop-in swap. Good to go.
The 3-port, eh.... you can hook and plug it up, but stay out of the boost-below wastegate pressure .
Intake you're good to go since you're staying out of the boost.
Exhaust manifold? If the gaskets are up for it, you're good to go. Careful with the bolts n nuts, especially for the turbo. They like to seize sometimes. PB Blaster is your friend.
Fuel rail is 2 bolts to hold it on and 4 bolts to hold the fuel line/FPR. The hardest part for me was to keep from dropping the lower orings on the injector. I must of dropped it like 6 times. I was about to pull an incredible hulk on it. I used a smaller 1/4 in ratchet with a short and deep socket 10mm for the fuel lines and a 12mm for the fuel rail its self. I also used a short and deep on the fuel rail do the the return fuel line brackets.
I'll tackle the exhaust manifold. It already has a broken stud in which I'll use "Easy Out" on if I can't get a grip and turn it out. Good call on the "PB Blaster". I plan on replacing all the studs since they look pretty rusted.
Forgive my ignorance as I has much to learn about the car and turbos. How do I stay below wastegate pressure? I won't be "getting on it" after I do the mods until getting it tuned.
Thanks for all the info!!
Good points! I'll let the shop do the install. It's worth $80 to prevent severe facial burns. LOL
Thanks for the writeup!!
