Disabling an Evo
Old Jul 12, 2011 | 06:58 AM
Lightsped's Avatar
Question Disabling an Evo
I will have to leave my car out for a few nights. What easy way is there to disable the car? My dad used to pull out a spark plug wire or two on his old cars. I don't really want to pull the battery.
Anything easy?
Thanks
Old Jul 12, 2011 | 07:08 AM
grim~'s Avatar
Just pull the spark plug wires,or the fuel pump relay.
Old Jul 12, 2011 | 07:10 AM
Lightsped's Avatar
Where is the fuel pump relay?
Old Jul 12, 2011 | 07:23 AM
vmrevo9's Avatar
Veteran: Air Force
pull the ignition fuse too.
Old Jul 12, 2011 | 07:26 AM
1UpMoto's Avatar
You could unplug the crank sensor also.
Old Jul 12, 2011 | 08:53 AM
SmurfZilla's Avatar
I would say take the ECU but apparently thats how they are driving away Evo's (Unplug your ecu and putting their own in, thus bypassing the immobilzer.
Old Jul 12, 2011 | 01:00 PM
J.J4ck0wsk1's Avatar
Basically anything that will mechanically immobilize the car and/or prevent it from starting.
Place the car on jack stands and take all 4 wheels off lol.
Old Jul 12, 2011 | 01:25 PM
MikeB@FFTEC's Avatar
I would probably recommend doing a couple of those steps listed above. Anything you can do to slow thieves down or deter theft is recommended.
Old Jul 12, 2011 | 01:26 PM
revvin9k's Avatar
Usually, if they want it bad enough.....nothing will stop em if they are experienced
Old Jul 12, 2011 | 01:40 PM
evo8426's Avatar
remove an intercooler pipe or the maf sensor. or disconnect the 2 plugs on the coil packs and put the spark cover back on
Old Jul 12, 2011 | 01:44 PM
SME's Avatar
SME
Remove motor and steering wheel.
Montu's Avatar
I would keep the battery so that your alarm keeps working (if you have one)
I would say pull the fuel pump relay and something to do with ignition like pulling a spark plug wire
Old Jul 12, 2011 | 02:01 PM
True. Or if they have a buddy who drives a tow truck.
Old Jul 12, 2011 | 02:06 PM
donmeca2020's Avatar
easiest way is to just remove your battery.... normally criminals are trying to make a fast gettaway, if the car doesnt start then that means it'll take more time and they arent gonna want to bother with it. easiest as i said is either remove your battery and block your car with other cars from your household.
Old Jul 12, 2011 | 02:24 PM
Most Hated's Avatar
so have you decided what your going to disable and where your going to put it?
no friends or family to store it or atleast move it around.
