Issues with keyless entry
Old Jul 14, 2011 | 09:39 PM
impact blue's Avatar
Okay I have a keyless remote entry system that came with the. Im having issues that I never got a chance to get around to it till now. The remote keyless entry is not working at all. Can anyone help me I tried all the procedures with the pushing the hazard button a series of times along with the paperclip in the jumper wire on the obd2 accessport.
Now I tried it it worked or so I thought the car locked then unlocked itself and that was it. I tried locking it after I took the key from out of the ignition and nothing happened. I have a boost controller can it be that somehow it is messing with it. What should I look for really looking for some advice im too lazy to use my own damn keys. help
Old Jul 14, 2011 | 10:08 PM
mt057's Avatar
Try swapping in a new battery into the remote.
Old Jul 15, 2011 | 09:50 AM
Im sorry I forgot to note that there is a new battery in there I changed it out that same day I was performing the procedure. Because that what I thouht it was. Where should I check next?
Old Jul 15, 2011 | 10:39 AM
crazybaldhead's Avatar
Make sure you have the same brand of battery. I know it sounds stupid, but some brands don't work. Try a Maxell.
Old Jul 16, 2011 | 02:01 AM
Tfresh's Avatar
Could be a broken key sense switch. Its a little plastic piece that has a contact and bridges two connections. This was the problem for me and if you did any work on the steering column its probably your case too.
Old Jul 16, 2011 | 08:38 AM
can i get get a picture of what it looks like?
Old Jul 16, 2011 | 10:55 AM
Is this what it looks like what do I do with it?
Old Jul 16, 2011 | 10:56 AM
Yes btw the car chime is on when I open the door and the key is not in the ignition. I see a small crack in it I think it popped out when i was replacing the airbadg and I did remember the spring that was in the piece but I didnt know where it came from but ohwell no sense in crying about it. Now what do I do? already took care of it now my **** works thanks ahh keyless entry a lazy mans dream if only it was like this for some females. Just dont reply anything just point at her unlock the ***** and go.
