best way to spend 5 grand?
Old Sep 5, 2011 | 03:27 PM
kanyonkid's Avatar
Start with pte 1200's, double pumper or dw300, E85, MBC and a tune,
if you want more,
arp head studs
gsc s2's, kelford 272's, fp 4r's
Intercooler 3.5" with 2.5" pipes
hta green boost 25-30psi
then if you want more safetly, build or block..
But before you do anything, do a compression test and find out what clutch you have.
Old Sep 5, 2011 | 05:10 PM
kcustado's Avatar
what will i need for a e85 conversion??
and im currently having a problem, i build boost to 20psi, but around 4500~6000 WOT i drop boost to 5-7psi.. i have no leaks in my piping, made sure everything was tight. i was thinking it's my wastegate actuator going bad?
Old Sep 5, 2011 | 05:28 PM
SavEVOIX's Avatar
Sounds like normal taper although a bit high. Do you have a MBC/EBC? Upgraded BCS?
Old Sep 5, 2011 | 07:43 PM
kcustado's Avatar
no, i dont have a MBC or upgraded BCS. i had the car reflashed at works about a month ago and the car ran great with no taper for about a week after. then out of nowhere it just started doing it, but when it happens you can hear the air escaping but i dont know where from.
Old Sep 6, 2011 | 01:03 AM
usnevo8's Avatar
ic plus piping, the works for e85, and bigger turbo.. but if you also want to make sure your car runs get it serviced lol make sure your nice to that tranny and tcase.. i had bc cams before on an e85 tune and yeah it was fun.. but i swapped out to some s2's and i love them.. better top end and it pulls way harder
Old Sep 6, 2011 | 07:36 AM
thepoint4life23's Avatar
put a stroker in it
Old Sep 6, 2011 | 01:03 PM
Dallas J's Avatar
Veteran: Army
Roth ira?
Old Sep 6, 2011 | 01:15 PM
EVOSE06's Avatar
That's only if he wants to save his money.
Old Sep 7, 2011 | 06:06 AM
evoimporttuner's Avatar
transmission
Old Sep 7, 2011 | 07:43 PM
warstang27's Avatar
it all depends on what you want out of your car. if you want the low end power/stock spool go fp green e85 1450cc inj aermotive 340 pump, intercooler, headstuds, gsc s1 cams and you should see around 450hp. if you dont care about spool go fp black instead of the green
Old Sep 8, 2011 | 12:45 PM
jDOTc's Avatar
me personally id go with a IC, and a little stock appearing turbo like a bbk or maybe a hta green and a retune....
with install cost, retune youll be right around 4 or 5k
4G63_Crazy
16
May 30, 2017 06:58 AM
3bar_dc2
Aug 6, 2015 10:08 PM
casper980
Feb 10, 2015 03:18 PM
boostedrb
18
Aug 2, 2012 02:22 PM
JorgeYaHeard
93
Dec 21, 2010 08:33 PM
