FP FAP Flow Advanced Port Cover -- Just ordered
Old Sep 8, 2011 | 01:00 PM
TheBoz's Avatar
So I have been trying to break into the 400whp/wtq on the stock turbo and stock cams. The car is right at the 380 mark at 28psi. I just cannot get it to go any more. If I add timing I see very small gains, and if I add boost I see small gains also.
Now from the results I have seen with the FAP, it seems that I might not make more peek hp/tq, however I might get a fatter power band. So if I can increase the spoolup and fatten the power band I think this thing will be worth its weight in gold.
I will have some VDR action next week, the FAP shows up on Monday.
After I do the FAP, then I send out my Intake manifold to MAP for some porting. If that still does not get me where I want, I will finally buckle and put some cams in the car.
Does anyone else have results with the FP FAP?
Figured I would add a pic.
Old Sep 8, 2011 | 02:47 PM
BenJ's Avatar
Just do the cams and you will be there. Kelford 280's or equivelant.
Old Nov 24, 2011 | 09:12 AM
HHIX's Avatar
Did you see any gains with the FAP Cover ?
Thinking about it as well...
Old Nov 24, 2011 | 09:25 AM
GdotRegEvo9's Avatar
why not go cams ? best bang for your buck, on top of it being for an 8.
Old Nov 24, 2011 | 09:30 AM
HHIX's Avatar
FAP Cover is 200 $...
good cams with install more than 800$ ?!?
and i have some surge which could be gone with the 84mm inlet ? Perhaps ?
Old Nov 24, 2011 | 08:48 PM
sparky's Avatar
Does TheBoz's Evo VIII have a ported TB? Did he do an IC upgrade? If so, which one does he rock? Who tunes TheBoz's car? Are you gonna do the Rev3 IM? Are you running an O2 dump as well? Although it is not the best bang for the buck mod, a ported cylinderhead would get you really close to your goal of 400 on the stock turbo and cams.
Old Nov 25, 2011 | 10:16 AM
TheBoz's Avatar
So here are the mods that I did.
MAP Version 2 Intake Manifold
Buschur Ported Exhaust Manifold
Buschur Ported Turbine Housing
FP Anit Surge Cover
FP 25psi WGA
JMF O2 Dump
Existing Modifications
05 Evo RS
AEM EMS
AEM 5bar Map
GM AIT
FIC 1100cc
Walbro 255 HP(moded)
Evo9 Turbo
AEM WRX Intake -- Jerry Rigged but looks good(no maf because SD)
Nesei LICP/UICP
Titek O2 -- Repalced with JMF O2 Dump
3" TBE w/Test pipe
Triggerdisc
Halman MBC -- Replaced with AEM EBC
QuarterMaster Twin
Solid Engine Mounts
Gates Timing Belt
Stock Fuel Lines
Stock Fuel Rail
Stock Fuel Regulator
Stock Cams
Stock Headstuds
Stock Bottom End
Stock Crank Pully
sparky
Ported TB == Nope
IC == ETS 3.5
Tuning == Done by me, and only me I will never let a tuner touch my car ever again(Except DB )
Rev3 == Nope the Rev 2 is perfect for what I need
O2 Dump == Yep, the JMF one
I am going to give up on my quest to keep the stock cams, they have gone about as far as I can make them go. I will be going GSC S2's pretty soon here.
I would say the main reason for the FAP is for the sound. God damn does it sound cool as hell. I am not sure what the gains were from the FAP becuase I bolted on a lot of other parts at the same time. I can tell you that my car drives much better, I dont get any compressor surge anymore.
HHIX
The price of cams did not prevent me from getting them, I was just trying to push the stock cams as far as I could. Also I would recommend the FAP to anyone running a stock turbo. If you are VTA the FAP will help a lot with that 5th gear freeway surge that always happens.
GdotRegEvo9
I am going to finally give up and go cams.
Old Nov 25, 2011 | 11:48 AM
Boosted Tuning's Avatar
FP Anit Surge Cover
FP 25psi WGA
JMF O2 Dump
Did you do all these mods at one time? If so, how are you gonna show the gains from just the FP FAP?
Also, if you were at 380 and just did all those mods in one round, then you should be able to hit 400, IMO.
Old Nov 25, 2011 | 01:42 PM
TheBoz's Avatar
When I ordered the FAP I was only going to do that part. however once I had everything appart to do the install I opted to do more. It kinda blew the testing of the part out. That is why I did not put any specific numbers. Tried to keep it as generic as possible.
For referance I use the MD setting because it seem to be better for me.
The car at 32psi is just insane. On VD MD Setting(412/415) VD DJ 473/477.
Here is my thread with the parts and gains from the parts:
https://www.evolutionm.net/forums/ev...parts-e85.html
AEM CAL and Log file
http://forum.aempower.com/forum/inde...c,28823.0.html
Old Nov 25, 2011 | 01:53 PM
TheBoz's Avatar
I also fixed my boost profile issues by ditching the EBC and going back to MBC. Now my car has a very nice boost profile. I am working on getting my dyno time in December so I can confirm numbers. Just waiting to hear if a slot is open for me.
Old Nov 25, 2011 | 01:55 PM
Boltz.'s Avatar
FCOTM Winner
You really need to do some cams. Besides the MBC, that will have better bang for your buck than anything you've done so far, imo.
Old Nov 25, 2011 | 07:57 PM
sparky's Avatar
....I am going to give up on my quest to keep the stock cams, they have gone about as far as I can make them go. I will be going GSC S2's pretty soon here....I would say the main reason for the FAP is for the sound. God damn does it sound cool as hell. I am not sure what the gains were from the FAP becuase I bolted on a lot of other parts at the same time. I can tell you that my car drives much better....
Khuuul! Yours is a nicely set up Evo.
Old Nov 26, 2011 | 01:08 AM
mmmmbst's Avatar
Veteran: Air Force
i dont have numbers but i didnt really notice a difference besides the awesome sound. Very doubtful this will break you into the 400whp area but the sound is worth the money.
Airflow86
Dec 2, 2016 10:08 PM
slipperychicken
May 20, 2016 05:40 AM
bryanf
Apr 28, 2016 06:06 PM
letsgetthisdone
Apr 25, 2016 06:39 PM
3bar_dc2
Jul 3, 2015 12:56 PM
