act hdss tob rattle
act hdss tob rattle
I recently changed my clutch, pressure plate, flywheel and tob in my evo ix. I have noticed there seems to be a slight rattle when driving or when starting from a stop when rpms may go low ( still getting used to clutch ). Is this a common problem? Anything I can do to fix?
Extremely common, which is why I purchase a Mitsubishi OEM TOB when doing a clutch such as an Act. Has something to do with the bearings ACT uses. As far as it being an issue, the only issue you will have is that noise, for the life of the clutch. When at a stop next time just push the clutch in the noise goes away. Don’t do this all the time, just to see if the noise goes away, if it does it is the TOB.
Mine does the same thing at idle in neutral with the clutch out....goes away when I push in the clutch....typical noise with the ACT supplied TOB....someone told me AFTER the install to use an OEM tob...oh well....
I had this rattle when I bought my car. Depress the clutch, noise goes away. Prev owner used the act tob.
Input shaft bearings also make this similar rattle when they go bad too.
With the next clutch install I used the OEM tob and for about 200 miles it was quiet then the rattle reappeared.
I have a oem clutch with 77,xxx and I get the same sound,so is it time to replace everything? Only mods I have are a works tbe I plan on adding licp, intake,cams and a reflash trying to make over 300whp so what type of clutch should I go with? thanks.
I went with the act hdss it will hold 450 ft lbs torque. As for the tob problem.. idk but I was able to get everything for 1k so if you want that website let me know
Everything: (pressure plate, flywheel, clutch, tob)
SQ2Evo
12
Feb 16, 2013 08:43 AM
Uryelowducky
Pacific Northwest
24
Oct 3, 2012 09:04 AM
