Cam sensor bolt threading issue
Old Oct 18, 2011 | 08:28 AM
BOOSTINAT30PSI's Avatar
Readers digest version:
I have a new motor that i am using and as i am swapping the cam sensor out of the old motor and into the new one, the bolt hole is too big for the bolt that was in the old motor.
I would assume that they should be the same size. The old setup had comp 280 cams, and my new setup has gsc s2 cams.
Any help or ideas?
Old Oct 18, 2011 | 09:16 AM
ProPilot04's Avatar
Get a bigger bolt? or make sure it's the right bolt/hole?
Old Oct 18, 2011 | 09:54 AM
I verified that it is the right hole, and bolt. I literally took it off one just to go to the other. I guess i will have to find a bigger bolt. I was wondering if anyone else went through this
Old Oct 18, 2011 | 10:00 AM
ProPilot04's Avatar
I'm sure someone may have. I don't have a built motor, so I'm not sure of the nuances there. I can't think off the top of my head why it might be a different size unless the previous owner stripped the threads and retapped them?
chrisff521
Jun 18, 2025 05:07 PM
Gtizks
Jan 15, 2017 04:05 PM
fireroasted
May 25, 2016 05:30 AM
Rome-Evo
Oct 8, 2015 03:53 PM
bluforu
Oct 21, 2009 06:27 PM
