Quartermaster Twin 8 leg
Old Nov 1, 2011 | 05:05 PM
alenewit3928's Avatar
I'm in the market for a new clutch, just wondering if anyone has any experience with the new QM twin 8 leg. Is the life of it worth buying it. I was also thinking about the Exedy twin but a lot of them fail where I live. Can you guys please help me choose a clutch. This will be going on a car making 450-500max torque.
Old Nov 1, 2011 | 06:49 PM
BEEVO67's Avatar
It's great for the price. You can get an Exedy twin for a few hundred cheaper, like the other half of evo owners, but I've owned both. The Exedy was good, but the new 8 leg is great. Holds 673 ft/lbs so far, shifting is great cause it grabs well, but I give most of the credit to the shep transmission. I've had the clutch for 4300mi now with drag passes and daily commute! Do it right the first time. Also would recommend Motul Gear 300 for tranny fluid. Best combo I've had.
Old Nov 1, 2011 | 06:51 PM
My tranny is at shep right now. Getting everything except the 4-11 final drive. Where did you get your QM?
Old Nov 3, 2011 | 02:06 PM
Go_Lancer_Go's Avatar
bump
Old Nov 3, 2011 | 02:19 PM
EvoJoeIX's Avatar
Exedy twin is a proven clutch. I have never heard of one failing due to the actual part being a problem (excpet the throw out bearing clip, but there is a fix for that, so if that happens, its the operators fault)
i have seen them fail due to abuse, improper installation and improper clutch adjustment though, but that will kill any clutch, none of them are unbreakable
Not saying the quaternaster isnt good, but not many people have it yet since its fairly new
Old Nov 3, 2011 | 02:25 PM
05blue8's Avatar
For the best qm deal contact Cisco at strictly modified...when I was in the market he had the best deals by far
Old Nov 3, 2011 | 03:47 PM
bcrance13's Avatar
I've had my 8 leg twin for about a year now...fantastic clutch. It grips like a son of a ***** and made shifting absolutely buttery at every RPM.
The ONLY downside to this clutch is that it is a monster for the street. It does squeak from a first gear engagement and it is very very touchy to get going, but the pedal pressure isnt much worse than stock. I dont mind having race car qualities for a street car, but the clutch is borderline.
I say get it if you can deal with the aggressiveness.
I can also post up pics of it from my install if you'd like.
Old Nov 3, 2011 | 03:57 PM
Strictly Modified's Avatar
Pm sent!
-Cisco
Old Nov 26, 2011 | 03:21 AM
most wanted's Avatar
hey i recently bought a Quartermaster 8-Leg Race Clutch Kit (Evo 8/9) but it didn't came with the Hydraulic Release Bearing so i was wondering if it can be used without the HRB
Old Nov 28, 2011 | 10:21 AM
You absolutely need the HRB.
Old Nov 28, 2011 | 10:25 AM
GTRicky's Avatar
be careful with the exedy twin. i have the HD, and was great for a good long while. BUT, now it's having issues with 1st/reverse due to a problem with the clutch
http://www.jackstransmissions.com/pa...clutch-warning
Great clutch, but you need to prep it properly before you install it. Mine wasn't prepped.
Old Nov 28, 2011 | 10:37 AM
suby2evo's Avatar
check this one out as well
https://www.evolutionm.net/forums/ve...-alt-hdss.html
Old Nov 28, 2011 | 10:41 AM
boosted91t's Avatar
Since your trans is at Shep, Ask John or Trevor what they think of the QM 8 Leg and make your desicion based off of that. I've had several discussions with them on this clutch
EVOMIZ
Jun 13, 2017 09:18 PM
Subawho_02
Aug 5, 2016 01:11 PM
2006GSR
20
Dec 28, 2014 04:23 AM
GHEvo8
10
Nov 1, 2014 01:52 PM
lilmarf
May 19, 2011 08:47 AM
