emergency brake question
Old Nov 5, 2011 | 09:32 PM
ksevo8's Avatar
so i just bought my car recently and i found out the previous owner drifted with the evo many times. my girlfriends brother just took my car for a spin and told me that i should change the ebrake. so how do i do that and what should i buy? its not as easy as buying regular brake pads. is it brake lines? please help! thanks
Old Nov 5, 2011 | 09:38 PM
HN7's Avatar
HN7
How did you come to the conclusion? Did the last owner told you that or you just guessing because the ebrake doesn't work well.
If the later was the case, the cable just need to be adjusted. Mine has been loose lately and can't stop the car from rolling back on the hill, had the cable tighten and works fine now.
Old Nov 5, 2011 | 09:57 PM
ksevo8's Avatar
the previous owner told me he drifted with it quite a lot after i bought it. its really loose like how you say yours is. can the brake cable snap by any chance? ill try tightening it first and hope it works
Old Nov 5, 2011 | 10:02 PM
KJS's Avatar
KJS
If you rip apart the center console, it will give you access to the ebrake wire. You can adjust it there with some basic tools.
Old Nov 5, 2011 | 11:44 PM
ksevo8's Avatar
do you know by any chance if the ebrake will snap off eventually? is that possible? and if so is there any better types of ebrake thats better than oem?
Old Nov 6, 2011 | 04:20 AM
5speedwtneed's Avatar
Just tighten cable. If its damaged or too stretched. Buy new cable. That's really it....
Old Nov 6, 2011 | 04:24 AM
Found this in another thread.
Originally Posted by ncaruso23
I would recommend adjusting the parking brake on the rear brakes not under the center console. All you need to do is take off the rear wheels and there is a little black rubber plug. Pop it out and use a screwdriver to adjust.
Old Nov 6, 2011 | 07:50 AM
ksevo8's Avatar
any chance you would have a picture or some sort? it would be really helpful for me to find it that way.
Old Nov 6, 2011 | 07:57 AM
Nope. I just got my evo 7 days ago. Just take off your rear wheels. And find that little black plug prolly on the caliper and tighten that screw. I'm tightening mine on Tuesday. That's my complete tune up day.
Old Nov 6, 2011 | 02:34 PM
shawn360h's Avatar
I just did a brake job on my evo and it didn't have the rubber plugs for the backing plate. It had the place for the cut out it just wasn't a hole there to adjust the parking brake.
Old Nov 6, 2011 | 04:41 PM
turbotalawd's Avatar
Always adjust the cable first. If that doesnt work, then its time to change out the brake shoes for the ebrake.
Old Nov 6, 2011 | 06:08 PM
white4g63's Avatar
just tighten cable. If its damaged or too stretched. Buy new cable. That's really it....
+1
Old Nov 7, 2011 | 05:59 AM
GTijoejoe's Avatar
Honestly, if the previous owner ripped the **** out of the parking brake constantly it is best to inspect the actual brake shoes and assembly of the drum brake components.
From the hand brake, there is a minor adjustment to aid with cable stretch. If you tighten this cable too tight, it will literally snap the threaded screw off the cable.... so dont do that, only tighten until the nut bottoms out.
If the minor adjustment is 100% tight, you need to look at the major adjustment at the parking brake. This is a star wheel that changes the clearance for the brake shoe to the drum of the disk. This adjustment is to aid with wearing of the brake shoes lining. This adjustment is very important, getting it wrong can lead to drag or self energization of the parking brake (lock).
Access to this adjustment on any parking brake is one of two places, from the back of the backing plate or from the front hat section of the brake disk there will be an access hole.
Often times, if there is no shoe wear and your minor adjustment is 100% tight, you need new cables
The service manual goes through this process.
ElectrIX Blue
Mar 21, 2014 06:51 PM
FAFRalliart
36
Apr 4, 2012 08:11 PM
evo4sho
Nov 7, 2010 06:02 PM
Turbo_Saloon
May 9, 2008 08:15 PM
SuckaFree
12
Sep 1, 2006 03:04 PM
