Broken FP RED [MERGED]
I am curious as to whether or not you had been running the FP recommended motor oil in your Evo. If so, then which brand of oil was it specifically? Also did you have the FP oil feed line installed or not?
Give FP a call. They've quit building new journal bearing turbos, but they still service and support their existing customer base, as far as I know.
Yeah Im sure that is exactly their mentality behind their products. God your a dumb****. You ask for help and then slam them, people like you man always pointing the finger. Your a ****ing newb that just joined today prob and this is your first post. WOW! You just ****ing suck in life.
There is a difference between asking for help, and bashing a product. You know exactly where im coming from.
I called FP they dont part out with rebuild kits.
Its not under warranty anymore sent them the invoice.
I will try to get it repaired by a turbo shop in Florida that recently repaired an FP Green on a Subaru forum.
i know what you are saying, but sometimes bashing is deserved. how many failed journal bearing fp turbos do we need to see every day before it becomes unacceptable?
Its ok I will have it fixed and will post info on the repair later.
I have taken picture of the damage and once it gets fixed I will elaborate more.
There are also many other components in your system that affect a turbo's longevity, including, most importantly, the oiling system. Everyone knows that the stock oiling (from the head setup) can be inadequate on an upgraded journal bearing turbo. Were you using the stock oil feed location, or feeding oil from the filter with the FP upgraded oil line?
Diid you ask FP to rebuild your Black, or just sell you the parts?
Frankly, it sounds like you just got on here to ***** about FP, seeing as you're already planning to have another local shop try to "fix it" and then telling us you're going to post up more about it. FP warranty service is the best around. They bend over backwards to help their customers who are out of warranty as well. I expect that if you treat them right, you'll find people are more likely to go the extra mile for you. Doesn't sound like that's the approach you're planning to take. I hope you get what you deserve.
It's a shame that people don't realize that turbos are parts that wear out -- the harder you (ab)use them, the more likely that they will eventually need a rebuild. Eighteen months of use shows that the turbo was not defective, or it would have failed long ago.
