do i need to retighten ARP headstuds?
Old Nov 15, 2011 | 03:47 PM
siduolocin's Avatar
Installed arp headstuds 1000km ago. 21psi + no water loss. do I need to retiten? Thanks
Old Nov 15, 2011 | 03:49 PM
Kracka's Avatar
I always like to check the torque, sometimes they've loosened a bit after the initial heat cycling.
Old Nov 15, 2011 | 06:47 PM
Frew's Avatar
I never retightened mine, I think as long as you follow the proper inital torque sequence you should be good.
Old Nov 15, 2011 | 07:25 PM
Murf's Avatar
Yes retorque them. The heat cycling will cause some to loosen a little
Old Nov 15, 2011 | 07:29 PM
WHTEVO's Avatar
I always re-torque mine after a couple heat cycles.
Aaron
Old Nov 16, 2011 | 12:12 AM
pacent's Avatar
This was one of the reasons why I choose map head studs instead of arp, they are designed to not require retorquing after install
Old Nov 16, 2011 | 03:28 AM
siduolocin's Avatar
So they are probably OK. But because we love are cars I will do them for fun will post results in two days time.
thanks everyone
Old Nov 16, 2011 | 03:43 AM
the real srt's Avatar
I always re torque head studs, no matter what bolts/ studs were used!
It makes sense to do so, doesn't it?
2 different metals tightened with another type of metal onto a soft gasket that go through extreme pressure and heat...
It takes 20 minutes and is a good insurance policy
Old Nov 18, 2011 | 06:47 PM
siduolocin's Avatar
Had taken me 2 hours and all was good. Torque was perfect.
Not a wast of my time we always Learn..
Old Nov 18, 2011 | 07:02 PM
BoostINurI's Avatar
Peace of mind is always good!
Black_EVO_MR
Jun 3, 2016 08:37 AM
icmanevo
11
Sep 21, 2012 12:55 PM
bbyevo8u
28
Jun 12, 2009 09:46 PM
gmore84
11
Mar 29, 2008 11:31 PM
kryptonitex
Aug 2, 2007 02:52 PM
