Fp black stock block
Old Nov 21, 2011 | 04:38 PM
mll's Avatar
mll
I am going to put a fp black on with a stock block how much psi can I push before the block gives? Also how much horse power can the stock block take before it goes I will be doing a 2.4 build at some point thanks
Old Nov 21, 2011 | 04:40 PM
evillancer06's Avatar
Veteran: Navy
before you get flamed i suggest you use the search button. Way to many topics/posts on this same subject. Good luck in finding your information
Old Nov 21, 2011 | 04:42 PM
CurseDSM's Avatar
As long as you keep tq under or around 400 ft lbs you should be fine.
mll's Avatar
mll
Thanks sorry I'm new
Old Nov 21, 2011 | 04:45 PM
wizzo 8's Avatar
Its torque not horsepower that kills motors. Like cursedsm said keep tq under 400
Old Nov 21, 2011 | 04:46 PM
binky's Avatar
Hey,
To give you some ideas, check out my build thread: https://www.evolutionm.net/forums/ev...-fp-black.html
Good luck!
-Bink
Old Nov 21, 2011 | 05:06 PM
EvoJoeIX's Avatar
i see a thread being created in near future.... "motor blew, what now?"
fp black on stock block is so stupid. the turbo makes to high of torque in relation to horsepower.
Old Nov 21, 2011 | 05:15 PM
mll's Avatar
mll
But is it also about the tune as well I have read that the tune has everything to do with the car and what you put in it
Old Nov 21, 2011 | 05:22 PM
fabcas311's Avatar
i thought the fp black produces lower torque compare to the green,bbk,hks?
Old Nov 21, 2011 | 05:25 PM
CurseDSM's Avatar
You sir are correct. The tune has everything to do with the way the turbo performs specailly on a stock block. If the tq is kept to the safe limit hp shouldnt play as big of factor and if done right the motor should last a good while.
EvoJoeIX's Avatar
Im saying if you need to stop at 400 tq, your hp is not gonna be much higher then that. All the stock frame turbos are like that. I mean it all depends on supporting mods and stuff like that, but fp blacks make high torque numbers for a stock bottom end to handle
Old Nov 21, 2011 | 05:26 PM
mll's Avatar
mll
That's what FP told me when I called they said the red and black a 25 psi would have the same torque and the green at 25 psi produced more
CurseDSM's Avatar
Not sure about the hks but the black is larger then the green and the bbk full. It also depends on what motor your running 2l vs 2.3 vs 2.4 etc plus how it is tuned.
Old Nov 21, 2011 | 05:28 PM
CurseDSM's Avatar
That is incorrect, if you stop at 400 tq any good tuner should be able to make as much power as they can with proper fuel and bolt ons to make more then enough power to make it fun and yet keep it safe at 400 or so tq
Old Nov 21, 2011 | 05:31 PM
mll's Avatar
mll
So I could have 600 hp as long as my tq is 400 or below?
