different screen to protect intercooler
Old Jan 30, 2004 | 09:58 PM
tlatoani's Avatar
How about one that rolls up on a spool, you know like a roll of film. It'd have to run in a track down both sides a la a garage door, with a semi-stiff frame. It would just take a little electric motor on one end of the axle to roll it up/down. Then you wouldnt have to worry about much space for it when it's in the free-flow position.
I'll probably cover mine when I finally get one...just to keep all of the damn bugs off of it.
Old Jan 31, 2004 | 07:20 AM
xtnct's Avatar
FYI, a reduction of airflow over an IC does not necessarily mean less cooling efficieny. Air flow over the extrior of the IC is not the only factor in the cooling efficiency. The IC may still be getting enough airflow to work at peak efficieny even with reduced air flow. Surface area, internal flow, etc., all goes into the equasion.
I suggest that you follow up on your original idea of doing the Gtec runs with and without the screen and get back to us. You may also want to stick in a temp probe before the TB to see if you read any intake temp diffs with and without the screen.
bsh
Jun 16, 2017 05:43 AM
Thoe99
53
Jun 13, 2005 03:27 AM
Turbocake
Feb 8, 2004 06:41 PM
SinCityEvo
Jan 28, 2004 12:43 PM
Thoe99
Aug 28, 2003 07:44 AM
