Mounting Oil Pressure Sender
Old Dec 2, 2011 | 05:31 AM
Tekniq's Avatar
Unhappy Mounting Oil Pressure Sender
How are you guys attaching you oil pressure sender?
1. via the bung on the block aboove the oil filer
https://www.evolutionm.net/forums/ev...e-senders.html
or
2. Using the oil filter sandwich adapter?
http://prosportgauges.com/oil-filter-adaptor-plate.aspx
If step 1 is the prefered way where do i get the 90 degree angle adapter? (step 7 in the instructions)
Old Dec 2, 2011 | 06:02 AM
thebluesky's Avatar
I use a variation of the first method and have my sensor mounted in a remote location. Having the sensor mounted on the motor wears them out.
Old Dec 2, 2011 | 06:07 AM
binky's Avatar
or
I did mine differently and I believe it's the best way to do it.
I used a line from AMS in order to install my Defi oil pressure gauge. It allows you to mount the sensor away from vibration (which extends the sensors life) and keeps the sensor from breaking off.
Here's a link to the line:
http://www.amsperformance.com/cart/A...Unit-Line.html
-Bink
Old Dec 2, 2011 | 06:55 AM
Tekniq's Avatar
Does the sensor just hand freely or is it then zip tied/bolted somewhere?
Old Dec 2, 2011 | 07:01 AM
binky's Avatar
Exactly. I zip tied it to the line that runs from the oil filter housing to the oil cooler, as seen here:
-Bink
Old Dec 2, 2011 | 07:27 AM
Tekniq's Avatar
Sweet. Thanks for your help.
Old Dec 2, 2011 | 08:13 AM
binky's Avatar
Sure thing man
-Bink
Old Dec 2, 2011 | 09:01 AM
bnr34rb26dett's Avatar
bink ftw
i was wondering y u had like 5 cables running from ur filter housing the other day lol
i am using the plate. no problems with the oil pressure sender. oil temp is another story. it has never worked since day 2. i talked to prosport and since they wont send me another sensor as part of a warranty i just bought myself another one..... it has not been installed yet
Old Dec 2, 2011 | 10:19 AM
binky's Avatar
Originally Posted by bnr34rb26dett
bink ftw
Your comment made my day
Haha, oil lines for everyone!
Yeah there are the oil lines going from the oil filter housing to the oil cooler, the FP oil feed line for my turbo and the oil line going to my oil pressure sensor.
-Bink
Old Aug 22, 2012 | 06:20 PM
anthonyrb98's Avatar
is it necessary to drain the oil completely when installing sensors in the oil filter housing? or can you just go ahead and remove the access plugs without too much oil pouring out?
Old Aug 22, 2012 | 06:26 PM
ATR's Avatar
ATR
It's cleaner to do it while you doing an oil change.
I personally just got adapter fittings to put my sensors in the oil filter housing.
Old Aug 22, 2012 | 07:17 PM
golgo13's Avatar
EvoM Community Team
Veteran: Navy
IIRC you lose about 300ml.
https://www.evolutionm.net/forums/9745443-post80.html
dtfrost5
May 13, 2016 06:33 PM
selp
Jul 5, 2014 04:37 PM
the1tonton
Jan 30, 2013 06:56 AM
golgo13
Jan 26, 2013 04:36 PM
trinydex
Mar 29, 2007 05:45 PM
