INSTALL: oil pressure and temperature senders
Old Mar 18, 2011 | 09:43 AM
  #76
x3evo's Avatar
Im new at this I always just research or figure out things on my own, but i tried and I i'm lost. Im working on a 04 evo I installed a PF2 green turbo so my feed line is connected to the bottom bolt off the filter adapter. My question is; would i be OK installing my pressure sender off the top bolt or is there any other way?
please any ideas would help. thank you guys.
Old Mar 19, 2011 | 12:41 AM
  #77
scothu's Avatar
I believe there is the t fitting that will utilize the oil feed and the oil pressure, or the sandwitch adapter will work. Hopefully my question gets answered
Old May 7, 2011 | 04:26 PM
  #78
Colbyy's Avatar
Soo what is the best way to hook up the oil pressure sending unit. should i get this http://www.amsperformance.com/cart/A...Unit-Line.html and mount it on the firewall? thats what i kinda read from here being the best way.. Will that be all i need if i get that ?
Old Nov 14, 2011 | 01:14 PM
  #79
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Anyone know if you can get away without having to drain all the oil?
How much will you lose if you drop the filter and the two sending unit plugs?
Old Nov 14, 2011 | 01:27 PM
  #80
deeman101's Avatar
Not much. Maybe 300ml. I had to pull out the filter when unbolting the control arms to give me space. Didn't take much to top it back up. Assuming the car is off and all the oil had a chance to drain back to the pan.
Old Nov 14, 2011 | 02:10 PM
  #81
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Good to know, wish I had known this yesterday when I dropped my LCAs...
Oh well, live and learn.
Old Nov 22, 2011 | 04:53 AM
  #82
r_ace_r's Avatar
I have hooked the pressure sensor on the block in place of the factory oil sensor and moved the factory one to the side of the head (removing the existing screw, the same as on the oil filter housing).
That's much more important place to monitor the pressure.
At idle I would recommend to keep around 30psi. 20 is way too low.
The best place for sensing a temperature would be oil pan (needs a welded nut for bolting a sensor).
Old Dec 6, 2011 | 05:03 AM
  #83
idyllik's Avatar
^ got a picture of where this screw is on the head?
Old Jan 27, 2012 | 11:35 AM
  #84
r_ace_r's Avatar
golgo13
idyllik
..finally got some pics
here is the place where I moved a factory oil pressure sender:
aftermarket sender installed in place of the factory one:
I had one additional pressure sensor with gauge laying around, so decided to hook it up to the head (note I have SAS disabled, it's valve, tubing and the mounting plate removed):
balance shafts are removed, bearings rotated and oil pressure reduced with an additional washer over the pressure regulating valve.
Oil: motul 300V 15w50
Pressure at idle (engine at operating temperature) -
Block: 1.9-2.0 bar (27-29 psi)
Head: 1.3-1.4 bar (19-20 psi)
Old Jan 27, 2012 | 11:43 AM
  #85
Dragracer187's Avatar
what thread is in the head? 1/8 npt or bsp?
Old Jan 27, 2012 | 03:56 PM
  #86
r_ace_r's Avatar
it's 1/8 npt, senders thread straight in..
..i was mistaken regarding the oil filter housing thread size in previous post, which is 3/8 bspt
Old Jan 27, 2012 | 04:28 PM
  #87
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Very nice!
How did you manage to tap the head without getting shavings in your oil? I assume you did this without the head on the car?
Old Jan 28, 2012 | 01:18 AM
  #88
r_ace_r's Avatar
threads are already in there, factory machined, just tapped with allen screws..
there are 4 screws on the head if i'm not mistaken.
you can actually install a factory sender with no modification.
For an aftermarket sensor you need either SAS (EGR) and its components removed or a suitable extension piping installed.
Old Jul 1, 2012 | 08:39 AM
  #89
explicitcarclub's Avatar
this thread rocks!! realy helped a lot guys thanks again!!!
Old Jul 1, 2012 | 09:44 AM
  #90
EvoVIIIFL's Avatar
Ive got the aem analog oil pressure sensor and just replaced the factory oil pressure sensor(dummy light) and it works fine no worries
