INSTALL: oil pressure and temperature senders
Im installing the Oil pressure and temp gauges this week. Already took the 2 bolts out, was very hard to get them out I may add.
As for sealent, Im going to use Permatex High Temperature Thread Sealant. Using taflon tape is not recommended, as it creates a barrier between the engine and the sensor. Sensor has to be grounded to the engine, and if not, it may give you incorrect readings
heres the link, click click
yea i did this install last week... i did need a breaker bar... besides the fact that my garage is not as roomy as i would like it to be... lol. great write up btw, i had read thru it a couple of times before i even started working on the car.
im using teflon tape... and it hasnt given me any problems yet, but we'll see
thx for teh write up!
my sensor runs an oil line to the cabin on mine, so is it okay still to use teflon? or is it absolutely necessary to use threadlocker still?
Did you get the metric adapters?
going to use this HOW-TO Sunday and finally install my Defi BF oil temp/press gauges.
I have a 42draftdesigns install fitting and thread sealant, OEM filter and oil.
Will let everyone know how it goes.
