INSTALL: oil pressure and temperature senders
Old Feb 1, 2018 | 12:20 PM
  #136
heel2toe's Avatar
I was wondering the same thing. There are 2 ports however on the OFH. Since both sides see pressure my thoughts would be to mount the pressure sending unit on the pre filter side and the accusump on the post filter side. It looks like the axle is right there so some clever fittings and a remote braided line is probably needed but a braided line is advised anyway.
Old May 6, 2018 | 03:27 AM
  #137
3gturbo's Avatar
You need to use a plumbers torch to hear up the housing around the plug to melt the thread locker, other wise you'll never get it out.
Someone should edit the original post those plugs have high temp thread sealant that wont break loose unless it sees about 500 degrees
Old May 6, 2018 | 11:39 PM
  #138
2006EvoIXer's Avatar
Lightbulb
Originally Posted by dave_evolvix
Checking in to see what ports people are using if they have an Accusump system installed as well? The how to I've seen uses the same port for the accusump, so I'm curious where they are installing sensors.
Old May 7, 2018 | 06:23 AM
  #139
CaptainSquirts's Avatar
I was able to loosen it just using a wrench with an allen key attachment. But that sucker was on there goooooooood.
Old May 17, 2018 | 03:09 PM
  #140
huzzle101's Avatar
I am having a real hard time getting this sucker off, its on there tight, think i maybe damaging it, any suggestions ?
Old May 17, 2018 | 04:52 PM
  #141
Pal215's Avatar
If you are able to get the right sized allen socket on there, use a breaker bar with extension and it should loosen fairly easily. Just make sure the allen socket is seated fully into the plug. I was able to remove mine without using a torch to heat it first. I don't like the idea of fire near that area of the car. If the thread is damaged when you remove it, then it was very likely damaged when Mitsubishi installed it. It is an NPT thread after all.
Old May 18, 2018 | 09:34 AM
  #142
DaWorstPlaya's Avatar
Don't forget to put some permatex thread sealant before you a plug back in or else it will leak oil. Ask me how I know ....
antics22
Evo X How Tos / Installations
201
Jan 5, 2022 06:24 PM
Jp7
Jul 30, 2017 05:29 PM
antics22
267
Dec 6, 2016 08:40 AM
trinydex
40
May 31, 2016 01:56 PM
500whp.com
87
May 31, 2016 01:30 PM
